mapguy
Mar 22 2014, 10:38 AM
Lucky for you I'm finishing my coffee
Updated avatar, and if I can figure out the editor here... I'll add one more front shot and one of the day I picked it up.
Shots make hood look wavy, but that must be a reflection. It's actually quite straight.
early '74 2.0 - early gas tank and silver dot gauges. Originally Zambezi Green. PO painted it white sans sail panels. I actually like the color, but may replace the sail panels. At least he left the trim on for me.
poorsche914
Mar 22 2014, 12:07 PM
Met up with Donald on his way thru Knoxville.
Here is my Creamsicle hanging out with the
Trailer Ice Queen.
hot_shoe914
Mar 22 2014, 09:06 PM
bobo914
Mar 22 2014, 09:22 PM
Dusted off, took out for a spin and a few pics.
pjhaun
Mar 22 2014, 09:26 PM
Today I finally finished installing my LED (running, brake, turn signal) lights. Here is a video to see how they work.
http://youtu.be/4G2-ViE75KE
partwerks
Mar 22 2014, 09:36 PM
Took out the purge control valve, and capped the 3 lines where they went to.
Justinp71
Mar 22 2014, 09:46 PM
QUOTE(bobo914 @ Mar 22 2014, 08:22 PM)
Now that's what I call a sleeper
Nice headers too!
bobo914
Mar 22 2014, 10:02 PM
QUOTE(Justinp71 @ Mar 22 2014, 08:46 PM)
Nice headers too!
Thanks they sound amazing!
DRPHIL914
Mar 22 2014, 10:23 PM
Started it for the first time in months, since replacing the push rod tubes and seals, clutch, flywheel, front and rear brakes and brake lines, bushings , bearings, new.5 lug, new.tires and fuchs!
Even though my brake pedal is still soft because I think I am still leaking from the supply line at the m
C. I coud not help but take it for a drive!!!! First run in 5-6 months and started in the first try! Idle warm at 900.
Not bad for a d-jet. Alsw was my first.time setting.the valves so I was happy to hear it run so smooth!
Still have to work out the brake issue, but I might give in and.let.the local porsche shop do it.
I have to give props to PMB and Eric , Bruce Stone for helpimg.me with most of what i have.
Oh, i forgot how much fun theae cars are to drive!!!
914_8
Mar 22 2014, 10:28 PM
Today I flushed and bled my brake system, fixed a wonky wheel stud and wired in a fan switch for my radiator.
bulitt
Mar 23 2014, 04:48 AM
QUOTE(Philip W. @ Mar 23 2014, 12:23 AM)
Nice job Philip
kid914
Mar 23 2014, 09:26 AM
Today I added some jewelry to my tach face.
Then I carbon fiber wrapped the gauge bezel.
Qarl
Mar 23 2014, 09:31 AM
QUOTE(kid914 @ Mar 23 2014, 11:26 AM)
That is way cool!
kid914
Mar 23 2014, 11:10 AM
thanks qarl! :-)
mapguy
Mar 23 2014, 09:36 PM
Tune-up, valve adjustment, replaced all vacuum lines and then...
Very happy new 914 owner. Carving these local canyons is kind of awesome.
ThinAir
Mar 24 2014, 12:21 AM
New fuel pump installed. Drove it for the first time since October 2013. Just in time to take it to my first day at a new job tomorrow!
pneuhyde
Mar 25 2014, 02:44 AM
results of a little work with said leather cleaner and prelim of dash with new cover and refreshed gage set and visors.
Looking for help on the best way to glue plastic dash cover onto old cracked dash?
KENNY
Mar 25 2014, 04:25 AM
I didn't use any glue on my plastic dash board. It fit like a glove.
jrrhdmust
Mar 25 2014, 07:50 AM
Sand and painted front trunk hinges, and bolts.
blackmoon
Mar 25 2014, 12:27 PM
finished installing a remote oil filter and new clutch/throttle cables, next up replacing fuel lines and speedo cable
ndfrigi
Mar 25 2014, 01:39 PM
Installed this muffler after temporarily used the 4 tip Ansa/monza muffler.
Better rounded sound although it is loud.
Click to view attachment Click to view attachment
euro911
Mar 25 2014, 02:39 PM
Stuff a potato in the tail pipe ... that'll quiet it down
JStroud
Mar 25 2014, 04:09 PM
I sold it, the "driver" is gone.....but 914world gets a new member....and McMark gets a new customer....everyone wins. And I went for a drive before it left.
Now time to focus on the white car, hoping to get the -6 in and running in time for WCR
Jeff
pneuhyde
Mar 25 2014, 11:11 PM
QUOTE(KENNY @ Mar 25 2014, 03:25 AM)
Thanks. One of the ideas I have had, thinking it might get pinched on pretty tight on each end. Cant say it fits like a glove though. I was thinking of shaving down any raised areas on the original where it was cracked and that might help the fit.
euro911
Mar 27 2014, 03:17 PM
Got back from my desert trip on Sunday night. The Westy needs a bath
Click to view attachmentI took delivery of a set of '99 MBZ CLK 320 wheels on Tuesday. I cleaned up one of them, filed down some curb rash and painted it with Rustoleum High Performance Wheel Paint (#248927 'Steel'), which is a silver metallic paint. Three more to go ...
Click to view attachmentI removed a paper clip that was sitting atop the front left tire on the 'BB' ... more than likely placed there by one of the local PD's 'meter maids'. I don't know why they keep screwing with my car ... it does need a bath, but it doesn't look
that bad. I guess I should take it for a another drive, for more than one reason
Mblizzard
Mar 27 2014, 06:47 PM
Addd a little accent light for better night time visibility.
Click to view attachmentClick to view attachmentA few LED strips inside the deck lid makes quite a statement.
bajafreaks
Mar 27 2014, 06:50 PM
Pulled the engine and trans. today, the engine is out of a vanagon 80-83 its been rebuilt but I just don't want it, thinking I'll list it on the samba and then start from scratch trying to replace/rebuild the correct 2.0 engine.
ablesnead
illegal color in a lot of states...mimics emergency vehicles
timothy_nd28
Mar 27 2014, 06:52 PM
QUOTE(Mblizzard @ Mar 27 2014, 05:47 PM)
I'm on the fence with this one Mike. Make a better statement by adding a few rows of red led's. I can build you a circuit that would oscillate between both colors!
Mblizzard
Mar 27 2014, 06:55 PM
QUOTE(ablesnead @ Mar 27 2014, 04:50 PM)
My research indicated that as long as they don't flash, it is not considered to mimic emergency vehicles.
timothy_nd28
Mar 27 2014, 06:57 PM
we can also wire this to your LED controller. As you hit 5k rpm, the blue LED's in the deck led would melt to a red color
Mblizzard
Mar 27 2014, 07:12 PM
QUOTE(timothy_nd28 @ Mar 27 2014, 04:57 PM)
I have a simple idea and then Tim hits it out of the park. Along that line, we will be coming out with a set of deck lid letters thar contain RGB LEDs that Tim is working with us on tying into his system. A bit in the future but It looks promising
jim_hoyland
Mar 29 2014, 04:08 PM
Installed a refurbished Bruce Stone pedal cluster. Pretty easy, still can't believe how fustrating the reattachment of the clutch cable is...
SKL1
Mar 29 2014, 08:24 PM
Drove the silver '71 for the first time this year after a winter of hibernation... started reasonably well and ran fine!
Helped my son with his new formula race car so the '73 didn't get much love today... hopefully tomorrow after I get up and watch the F1 race.
hblyle
Mar 30 2014, 02:47 PM
Installed some Fatmat today. Happy with the product, easy to work with and can't tell a difference between this and Dynamat.
orthobiz
Mar 30 2014, 06:00 PM
Took the car out of the pole barn FINALLY. Changed out some Euro front blinker lenses and installed American new ones.
Lots of things planned for the red car this year!
Paul
SKL1
Mar 30 2014, 06:46 PM
Boy ortho, you've got some serious snow melting to do!!
Luckily we finally got rid of our white stuff so my son could get out his new toy- gotta get it ready for his first race in it in a month!
Steve
Mar 30 2014, 06:56 PM
After two years, I am finally ready to put my 3.2 and 916 trans back in the car.
Before
Click to view attachmentAfter
Welded in new firewall plate to cover big steel braided line hole and replaced with S&S Fuel Lines. Also replaced all rubber with Mikey Rubber.
Click to view attachmentHell Hole Before
Click to view attachmentAfter (maybe too much seam sealer). Restoration Design Engine Shelf. Great products, people and service.
Larmo63
Mar 30 2014, 06:58 PM
Bought a work table and bench grinder at Lowe's. Replaced the grinder wheels with a wire wheel and a polishing disc. Polished/ww'd the rusty lug nuts, they look great. Started with my polisher on the new/old set of 2.0 Fuchs, new tires tomorrow! These will have to be done professionally, at some point. Car is still at the shop, can't wait to drive a 914 (someday?) This is tough, sitting here with no car to fart around with, or, drive, for that matter! I dream of actually driving it.
Steve
Now ready to put my 3.2 and 916 trans in the car. Project for next weekend!!
carr914
Mar 30 2014, 08:41 PM
dangrouche
Mar 30 2014, 08:55 PM
used the HF tool and removed the windscreen trim, then re-shaped the trim with a channel lock (without marring the trim) where the clips hold the trim. just a gentle squeeze to restore the integrity of clipping surface.
euro911
Mar 30 2014, 09:00 PM
My trim keeps popping out at the lower right corner, I need to do this too.
Did a 7 mile round trip down to Ruby's Restaurant at the Redondo Beach Pier, was a beautiful day for a top-off drive
eyesright
Mar 30 2014, 09:19 PM
I have two LE wheels in one corner of the garage and a Continental 165-15 tire in the other. The wheels I got some time ago at a junk yard and the tire has been hiding in the corner so long I forgot where and when I got it. I figure its decades old of course but looks brand new, never been on the ground.
So,... got up early and not ready to start rebuilding brakes, I hit Walmart to have the tire mounted just to have the fun of rolling it around the garage when its in the way of whatever project is going on. I remember those skinny tires and distinctive treads and wish they still made them.
914itis
Mar 31 2014, 06:03 AM
In Preparation for Hershey, I did an oil change, reinstalled my gauges (converted and new LED by Tim ) he did a great job. Installed a fitting for easy oil drainage from tank.
Luke M
Mar 31 2014, 07:18 AM
QUOTE(914itis @ Mar 31 2014, 05:03 AM)
Looks like the fitting to the left of the T fitting isn't seated all the way. There shouldn't be any threads exposed. You may want to check that before it comes apart and drains all the oil from the tank.
914itis
Mar 31 2014, 07:28 AM
QUOTE(Luke M @ Mar 31 2014, 09:18 AM)
Thanks Luke> will do
914dave
Mar 31 2014, 07:38 AM
Started fitting glass bumpers. Had to remake the angle of the front bumper bracket.
Click to view attachment Bonded then with fiberfill bondo. Will overlay fiberglass on them when I take them off.
I'll have to add some on the edges to get an even fit. It is progress.
R8CERX
Mar 31 2014, 07:42 AM
QUOTE('73-914kid @ Mar 12 2014, 03:14 PM)
QUOTE(Michael N @ Mar 12 2014, 02:47 PM)
Drove it to lunch with the kids. Perfect weather today in Los Gatos.
Click to view attachmentLove the small Brumos sticker in front of the door. Just a little touch..
How do you handle the coos if stopped- three in the car? No third seat belt?
Curious...
JStroud
Mar 31 2014, 08:36 AM
QUOTE(R8CERX @ Mar 31 2014, 06:42 AM)
Curious...
Michael has a third seat belt installed......for the kids...what a great Dad.
