QUOTE(Philip W. @ Jul 23 2014, 09:24 PM)
... oh, and he also set the valves- they were on the tight side, but timing is not perfectly set at this time, because my TDC mark is gone!- so I have a question, what is the best way to mark it? - ...
Phil, to find TDC:
1. Remove your dizzy cap and take note of where cyl #1 spark plug wire is
2. Remove cyl #1 spark plug
3. Jack car up so one rear wheel is off the ground (or if both, chock one of them)
4. Place the shifter in 5th gear
5. Have an assistant rotate the un-chocked wheel until you see the dizzy rotor is pointing at cyl #1 firing position
6. Insert a chop-stick into the spark plug hole ...
6. Insert a long plastic straw into the spark plug hole so it contacts the top of the piston
7. Have your assistant rotate the wheel forward and backward several inches while you are watching the straw move in and out of the hole. When the straw is at the highest point, you're at TDC for that cyl.
8. Verify again that the rotor is still pointing at cyl #1 firing position
9. Locate the notch in the inspection hold on your fan housing and paint a '0' on the fan
10. Measure the distance forward of TDC to mark your ignition timing mark (this depends on the specific engine that you have)
There is a good tech article on Pelican, including a gauge you can copy, cut and place on your fan to mark your particular ignition advance setting, again with a dab of paint. You may wish to paint TDC one color and your X° BDC mark with another color.
one other question-how do you tighten up the steering column? it has a bit of up and down play to it?
There is a steering shaft bushing that you can replace (I need to do this too). There was a recent thread on how to do it. I don't remember exactly where, but it may have been in
this thread ...
