Well the staycation is coming to an end.
1. Got the engine back in and she fired right up after the fuel system got filled and pressurized. A couple fuel lines needed to be tighten, but still runs like a new car.
Even with one of the lines at the charcoal canister left open.
But then I found the return pipe on the fuel tank was dripping.
That's the one I had the thread issues with. So out came the fuel tank, again.
Looks like I could have used another 1/4 turn. But doped her up the Permatex with Teflon thread sealant. We'll give her a week to set up.
2. Then installed the JWest fog light flasher.
Works really cool. But now I'll have to buy some new fog lights from Camp914.
3. Then I stepped up and went after installing my new updated fuse panel.
wasn't the Jwest one. Pretty easy to install. The center section that covers the fuse box on the backside is pretty thick. Which makes getting the wires spread side to side is pretty tight.
I may take it out and open up the factory taped up wire bundle and separate them four connections at a time. I also might add a couple 1/4" nylon spacers to give it a little more space for the wires. But she looks nice and tidy.
All and all a good week ...................... too bad it's almost over.
