Pushed mine out of the garage so my baby girl could play in it.
Tman914
Oct 5 2014, 11:36 AM
QUOTE(oldschool @ Dec 29 2011, 11:52 PM)
Ive been stick with a fuel problem ...I think? but now I'm on a full blown kitchen remodel..please some one come over and help me replace my fuel pump
Old school where did you get the lift rack at was it worth it and useful
BobR
Oct 5 2014, 12:59 PM
Went to Ocala Cars and Coffee. Finally some nice cool weather. Installed new KYB inserts in the front struts, New KYB struts in the rear and 100# springs in the rear. Click to view attachmentClick to view attachment
BeatNavy
Oct 5 2014, 06:29 PM
QUOTE(914nola @ Oct 5 2014, 12:50 PM)
Wow. That's not cute or anything. Not at all...
BeatNavy
Oct 5 2014, 06:41 PM
Loooonngggggg weekend. Got my teener off of jack stands after of week of tackling several projects, all of which were more or less dependent on the gas tank being removed. All three projects finished up today:
1. Replaced the master cylinder. After bolloxing up the one I bought I managed to use the one in my project teener, which I think is also a 19mm. After a power bleed everything seems to be working well. Wow, this project was a real PIA, and I learned a lot the hard way.
2. Cleaned up the fresh air blower that had never worked and managed to get mid and high speeds working (but low just gets the resistor hot and smokes and the fan doesn't move). Wow, this project was a real PIA, and I learned a lot the hard way.
3. Got the electric windshield washer pump installed and triggered off the column switch (924 wiper switch). Up to now the car has not even had the stock windshield washer solution, so it's good to have something in place. Wow, this project was a real PIA, and I learned a lot the hard way.
4. As a bonus, while the car was on jack stands I put new, wider tires on the rear to replace the OLD, cracked, pitifully thin tires that were there previously. This was not a PIA. It was easy and satisfying.
After all that, it felt REALLY good to fire it up after a week and take it for spin. Thanks for everyone's help and encouragement as I got through this. I managed to check off a lot of "to-do's" but boy were they a PIA!
Sleepin
Oct 5 2014, 06:44 PM
Chopped more crap off:
balljoint
Oct 5 2014, 07:02 PM
Please see Sleepin's WTB in the classifieds. He's looking for a nice set of BUBs.
914nola
Oct 5 2014, 08:20 PM
Since it was pushed out of the garage for play time, I figured I would tinker with it. I have been scared to start it since it has been in storage for 20 plus years. I changed the oil, hooked up jumper cables, added fresh gas. First key turn, motor spun. I was happy it was not locked up. Second turn, spin and sputtered. Surprised would be an understatement. Third key turn, motor started and had a good idle. Completely shocked. I let it run for three mins then shut it down. It was just the thing I needed to make me keep it. My dad and I had talked for years about "getting it running". He passed away a year ago. My new goal is to get it road worthy, drive the dragon like we said we would. I will just have to do it with my lil girl in the passenger seat. Time to make new memories with the "tiny red car that winks" as she calls it.
Sleepin
Oct 5 2014, 08:53 PM
That's pretty cool right there!
Mike Bellis
Oct 5 2014, 10:18 PM
I topped off the methanol tank and took it to 120mph...
Good luck. I'm sure there will be more "challenges" ahead, particularly after sitting all that time, but you've come to the right place. I started a little over a year ago on my '72 1.7L (red BTW, with the headlight that also "winks") that had been sitting for a LONG time. It's been a lot of fun, and this place has been invaluable. What year/engine/etc. do you have? And yes, your daughter is adorable. My 14 year old daughter LOVES riding with me in the teener just spinning around with the targa off. Hopefully you'll have a lot of memories with her.
DRPHIL914
Oct 6 2014, 08:06 AM
Drove it to work today , 55 degrees this morning- glad I hooked up the heat!
kkid
Oct 6 2014, 08:44 AM
Installed 17mm brake master cylinder today. The infamous feeder lines and rubber grommets were fairly easy to go in. It took me 30 min to figure out (but had to spend few hours to read numerous threads in advance). The easiest way for me was to install grommets in the MC first, then lubricate the fluid feeder lines with WD40. Finally I forced them to fit with my fingers followed by a pair of pliers to conclude. As I was advised, made the fluid reservoir loosened on the above. Click to view attachment Question: how do you reset this sensor switch? My old one has a nipple to play with but this one doesn't let me
kkid
ClayPerrine
Oct 6 2014, 05:13 PM
QUOTE(BobR @ Oct 5 2014, 01:59 PM)
I wish I had known you were in Ocala. Betty and I could have visited the last time we were visiting her father in the Villages. We are always up to see someone's 914.
URY914
Oct 6 2014, 06:21 PM
Bought a new battery a few weeks ago. I had to fab a new hold down bracket as this is larger that the last one. Cleaned up the carbs and fired it up. Still working on my revised air intake scoop.
euro911
Oct 6 2014, 07:40 PM
You guys have been busy.
The time I thought I had earned from all the 'honey-doos' got put on the back burner - again We had another skunk take up residence under the house and took us almost a week to get the bugger out. One of our dogs found a way under the house too and guess what? ...
Well, after giving Kiddo a bath, I started refurbishing and making new crawl-space vent screens all around the house. Only have two left to go, but those are structurally sound, so they can wait until the rest of the trim gets painted next summer. I think we've got all the possible areas of entrance protected now
The weather is supposed to start cooling off (been in the high 90's and 100's) so hopefully (geeze, I get to use that word a lot these days) I can get to the shop later this week for some fun with grease and grime for a change
BobR
Oct 6 2014, 07:55 PM
QUOTE(ClayPerrine @ Oct 6 2014, 07:13 PM)
Next time you are down give me a call. I am actually in the Ocala National Forest just East of Silver Springs, about 25 minutes from the Villages. There are some awesome roads with twisties through all the beautiful horse farms here.
BobR
Oct 6 2014, 09:09 PM
Took my granddaughter out for a ride through some twisties today. She was yelling and screaming "Woohooo, this is like riding a roller coaster."Click to view attachment
JoeSharp
Oct 7 2014, 04:25 AM
QUOTE(BobR @ Oct 6 2014, 06:55 PM)
Hey guys, I too live in the Ocala Forest. Let me know when your down here and I'll crash your party. Bob, I'll meet. you at the next Coffee and Cars in Ocala.
Yesterday I pulled the tranny from the race car and today I'll pull the one in NICE and tomorrow I hope to put the race cars tranny into NICE.
slivel
Oct 7 2014, 12:57 PM
Installed new lexan windshield on the race car. The old one was very pitted and scratched. Now I have to install the sun shield along the top. Click to view attachment
Chris H.
Oct 7 2014, 01:39 PM
QUOTE(BobR @ Oct 6 2014, 10:09 PM)
That's what it's all about right there. Well done Bob.
euro911
Oct 7 2014, 02:48 PM
QUOTE(Joe Sharp @ Oct 7 2014, 03:29 AM)
NICE
How is Linda doing?
PM me your new cell #
BobR
Oct 7 2014, 03:06 PM
QUOTE(Joe Sharp @ Oct 7 2014, 06:25 AM)
It is held the first Sunday of every month, 8-11am. We hold it on the NE corner of SR40 and NE 25th Avenue in the parking lot next to Discount tire. See you there.
Thanks. I am sure we made a memory she will keep for life.
hndyhrr
Oct 7 2014, 09:06 PM
didn't do a darn thing today
Had to put 4 legged kid down and don't have the heart to do much of anything.
JoeSharp
Oct 8 2014, 10:47 AM
Hey Mark, you have PM. Today I'm about half way done putting the tranny back in.
euro911
Oct 9 2014, 04:01 AM
QUOTE(hndyhrr @ Oct 7 2014, 08:06 PM)
We have to make tough decisions sometimes ... been there
Remember him/her fondly and rescue another one, they'll bring joy back into your life.
Johny Blackstain
Oct 9 2014, 09:48 AM
Decided to put them both to work & had them do some modeling for me
abnrdo
Oct 9 2014, 12:25 PM
QUOTE(euro911 @ Oct 9 2014, 05:01 AM)
We had to do the same on the 7th. Prayers your way my friend. Be thankful you had them for the moment, as they will always be with you.
JawjaPorsche
Oct 9 2014, 01:43 PM
QUOTE(BobR @ Oct 6 2014, 11:09 PM)
Love the grins on BOTH of yall's faces!
ndfrigi
Oct 9 2014, 02:52 PM
Playing around with the cars this morning.
Picked-up a set of wheel dolly yesterday from Harbor Freight to be able to rotate and for easy to move the 71 1.7 (with rear suspension console damaged). Borrowed pedrini wheels from 71 and install it to 75 1.8. Wow pedrini is the right offset for our 914 even 205x65x15 really has more fender space compare to the riviera with only 185x65x15 tires that made me pulled the fender a little bit. Hoping someone will buy the red one soon (74 1.8 FI), still waiting if the member is still interested with it.
Rear view with 205x65 tire is way better than 185x65 as long you have the right offset like pedrini wheels.
thanks for kind words, will do when ready
hndyhrr
Oct 9 2014, 09:08 PM
QUOTE(abnrdo @ Oct 9 2014, 11:25 AM)
wow the same day, i am thankful for her, she was 18 and we had a good time for all of it.
it sucks coming home from work now. but she doesn't hurt and is running free, thanks for you kind words and my heart goes out to you also.
messix
Oct 9 2014, 09:35 PM
had a broken fog light, went to put in new jbugs fog light and the damn mount is different and spent way to long on that with the relocation hole and a bolt that interfered with the light bucket going down.
then put in new heater hoses from h/e to flapper .... I must have the wrong passenger side pipe from h/e to flapper cause the cable wont reach the flapper now but have heat on drivers side now
Out with the old in the the new dash! my friends shop installed my dash yesterday . I'll post a finished shot when i get the radio back in.
I had my dash recovered by: Dash Specialists 1910 Redbud Ln Medford, OR 97504 (541) 776-0040 I would recommend him to anyone that needs a dash
Dave
CatDaddy60
Oct 11 2014, 04:00 PM
I know I know this carb is the worst choice EVER!!! but I went through every orifice and cleared each one. Also replaced the accelerator diaphragm and power valve diaphragm on the Weber dgv 32/36 that I'm using to get this beast back on the road. Also picked up the phosphoric acid stuff for addressing the rust concerns. in the hell hole and other spots.
I did a test drive but not befoe changing out the starter. Nice drive NICE 914.
Mike Bellis
Oct 11 2014, 06:47 PM
I swapped out my throttle body. It would not auto calibrate. I dig ODBII & VagCom.
BobR
Oct 11 2014, 07:37 PM
QUOTE(JawjaPorsche @ Oct 9 2014, 03:43 PM)
Thanks. That is because we both are kids @ heart.
lonewolfe
Oct 11 2014, 08:45 PM
QUOTE(two914-6s @ Oct 11 2014, 07:40 AM)
Dave
Hey Dave,
what did they charge to recover your dash?
cary
Oct 11 2014, 09:36 PM
Here's blower fan videos I promised a couple weeks ago.
