QUOTE(euro911 @ Jan 7 2015, 02:23 AM)
QUOTE(914_teener @ Jan 6 2015, 08:56 PM)
QUOTE(euro911 @ Jan 6 2015, 05:27 PM)
QUOTE(Philip W. @ Jan 6 2015, 05:09 AM)
yesterday, checked a few connections, wiggled some wires, wont start.
----- again. probably wont try tonight--- i am about ready to part this out
well , i have acouple more thinkgs to rule out before giving up and throwing in the towel........
I agree....don't think a 914 is in his future.
Naw, he'll get it sorted out and have a fine running car again.
Let's go back to the beginning ... what all did you change out Phil? (I forgot)
Did you double-check against the trouble-shooting links on Jeff Bowlsby's site?
When you get back to it, check these L-Jet links out:
Bosch Volkswagen L-Jet Fuel Injection ManualL-Jet Fuel Injection for 912E (also applies to 914 1.8L cars)Also look for the other trouble-shooting tip articles on the main tech notebook page (
Click here )
"Let's go back to the beginning ... what all did you change out Phil? (I forgot)
really too much to write - everything- BTW its D-jet, 75 2.0. , last issue we did i.d. a back MPS, but never really figured out what was making it so lean that with a bad MPS it would actually run(with the vac hose off). replaced that and spent a week driving and tuning in another mps last 2 drives were showing the A/F right on the money, - TPS set, FI harness was new couple years ago from Jeff B, and mechanic tested all the connections and wires for conductivity etc. i guess the list would be long but fuel pressure- 28-29, fuel is there; a few weeks back when it was at bobs shop and he was sorting thru it for me i had had the same thing happen and i could not get it to start, so i trailered it over to his shop. SO it was exact same issue but at some point the mps failed, we replaced it and it ran- but i still think there is a bad connection somewhere in the system, he also must have messed around enough that it was not doing this . - fyi something similar happened about a month or so before that - one day would not start, same thing, walked away, came back a few hours later and it fired up on first crank! kind of forgot about it because it didnt happen again for over amonth until that fateful day.
since coming home from mechanic i have not touched anyting except reset the TPS because he had it set wrong, re-tuned the mPS and put in the new temp sensor- as you remember when i did that (it had quit running i could barely get it to run replaced that and suddenly it ran)-but of course the abient air temp sensor would not do that so i believe it was just a coinsidence - most likely moved the harness enough to cause whatever was shortingout to reconnect so it ran- for a while---
- what i forgot to mention is this week saturday when i whent to drive it and it didnt start, - it almost started at first, but was missing bad, could not keep it running, it died and then i could not even get it to fire at all - and since will not start - that episode, what it reminded me of was when one of the FI ground connections came loose a few years ago and was causing it to fire on one set intermittantly as it was hanging there and barely touching- that is what it reminds me of, but ive rechecked those and they are on their ground connections and ive re-checked the harness connection to the distributor f.i. points as well.
