Woke up with what I hope is only a 24-hour bug
- so didn't do much today
Later in the day Richard called and gave me some verbal instructions on how to fab a wrist-pin puller for cylinder #3. I rummaged through the junk pile and came up with this device:
Click to view attachmentHere's the Parts List:
(1) 7" length of 3/8" all thread
(2) 3/8" nuts (one is a locking/jam nut ... you can use a single Nylock if you have one handy)
(1) 5/16" flat washer (The OD of this washer needs to be smaller than the OD of the wrist-pin, but larger than the wrist-pin's ID, so it will grab the pin, but also pass through the rod bushing)
(1) 3" length of 1.5" diameter PVC pipe (I ground a 1/4" deep scallop into one end. This will butt up to the side of the piston and should prevent damage to the piston and/or the rings)
(1) 2" wide, 1/8" thick aluminum plate, with a 3/8" hole drilled in the center (I was lazy so I left the length of the plate long).
(1) 3/8" flat washer
(1) 3/8" all-thread coupling nut (a regular nut will work, this just happened to already be on the all-thread).
Theory of operation:
1. Remove the two nuts and flat washer from the tail end of the all-thread, insert the all-thread through the #3 wrist pin from the cylinder #4 side. Don't forget to remove both circlips first
2. Position the scalloped end of the PVC pipe against the #3 piston and reinstall the 5/16" flat washer and two nuts (snug them up and lightly jam them together - these take a 9/16" wrench).
3. Use a 1/2" or a 13mm ratchet type box wrench on the all-thread coupling nut. As you tighten up the coupling nut, it will pull the wrist-pin out of the piston and into the PVC pipe.
* EDIT - You may need to a insert a small screw driver between the wrist-pin bore and the doubled-nuts at the tail end, to keep the all-thread shaft from spinning when tightening the long all-thread coupling nut.
Unfortunately, I won't be able to test it out until tomorrow (if I feel better by then)
