Had to slightly modify the choke port plugs again
... Adjusted float levels, reassembled and reinstalled the carbs with new top and base gaskets.
Cranked to check for oil pressure, connected coil wire and started the car. Ran at 2500 rpm for several minutes, then checked plugs. Too lean.
...Increased main jets to 140. Ran again. Increased mains to 145 ... and it's still running lean
Engine is a brand new 2056, snotty (RABY 9580) cam, 9:1cr, 40 IDFs with 28mm venturis, 50 idle jets, I believe F11 emulsions, and I don't remember if the ac jets are 180, or 190 (I'll have to look again)
Looks like we're going to try 155 or 160 mains and possibly upping idle jets to 60
Readjusted the driver's side headlight, installed the front valance and horn grilles with all new s/s hardware, also installed a new passenger side window squeegee and new window end caps. (Feels good to get all the little parts installed that were missing when we acquired this car)
Still have a few remaining tasks to do, but I'm done for the day ...
