QUOTE(G e o r g e @ Jan 18 2016, 06:25 PM)
My phone never rang.......
looks like the leak was from the toilet above, bolts loose and the wax ring no longer worked. Cast looks good to me.
BOT I am close to pulling the 75 off the rotisserie and getting it over to you.
Sorry, never thought to bother you, George.
#1 - Leaking shower valve seats - installed new valves.
#2 - Leaking (deteriorated) drain/trap piping - old one had to be cut out with a saws-all
#3 - Toilet seal leaking - will be dealt with tomorrow.
#4 - Cast has multiple cracks and rust bubbles forming (not easy to see in the pix), and the old tamped-in joint seals leak ... so I decided just to replace all of it with ABS and never have to worry about it again
Our tenant is a family friend's son, and his step-dad is a plumber who lives a couple blocks away, so he was happy to come by and see what we could do to fix it.
I picked up all the ABS stuff at Lowe's, roughly $160. for everything. I'll eventually get around to building a removable soffit to cover the new plumbing when we're done - but this repair should last my lifetime
