Cal
Mar 30 2016, 09:28 PM
Currently replacing the original 42 year old plastic fuel lines and rubber brake lines in my '74 2.0L.
abes914
Mar 30 2016, 10:04 PM
QUOTE(Cal @ Mar 30 2016, 08:28 PM)
i encourage who have not replaces their orignal fuel lines to replace them soon or put it on top of their to-do-list! i recently replaced mine and with a little nodge of the gas tank, my return line turn into crumbs. my out line also snapped off with little force.
and thank you noel for helping me out. it would have taken me a whole day without your knowledge!
Mar 31 2016, 08:03 AM
Shadowfax
Apr 1 2016, 07:50 AM
Got the valves adjusted, new points (third set in a year...), checked timing and dwell angle and an oil change. Runs great.
76-914
Apr 1 2016, 07:57 AM
QUOTE(Shadowfax @ Apr 1 2016, 06:50 AM)
Damn are you replacing the condenser at the same time or did you put 40K on it last year?
Shadowfax
Apr 1 2016, 08:48 AM
QUOTE(76-914 @ Apr 1 2016, 08:57 AM)
Yes - new condenser each time. To be more clear, the first set I put on last year during the initial work I did on the car was heavily worn after about 10 months (and maybe 2,000 miles) and left me stranded. I could not determine the cause. The second set that was removed this week had a small "mountain" on the contacts so I just replaced them and the condenser for peace of mind. Am contemplating converting to electronic ignition at some point...
euro911
Apr 1 2016, 08:59 AM
Electronic is the way to go. Keep a-spare dizzy with points & condenser in the trunk as a back-up
76-914
Apr 1 2016, 09:24 AM
Definitely go electronic but keep a spare pair of electronic for roadside repairs. I don't recommend carrying a set of points as a replacement unless you also carry a dwell meter and timing light with you.
forrestkhaag
Apr 1 2016, 10:25 AM
Today's task / putting in a new speedo cable / third one in the last few months...... routing issues I presume / Bruce Stone relayed a "trick" to run the cable up and over the axels to the upper bolt/nut location on the side of the tranny / then install a cale clamp of the proper diameter to that stud to keep the cable in check / and test the angle drive for ease of rotation. fyi
lonewolfe
Apr 1 2016, 02:00 PM
QUOTE(forrestkhaag @ Apr 1 2016, 09:25 AM)
Do you have any pictures of the cable routing?
Apr 1 2016, 05:20 PM
Removed the car cover, gave her a shower and drove her around the block a few times ...
euro911
Apr 1 2016, 09:10 PM
QUOTE(76-914 @ Apr 1 2016, 08:24 AM)
Get a complete spare dizzy. Set the dwell and make a timing mark on the case (for cylinder #1) while that dizzy is in the car, then remove it and toss it in your bag-O-tricks in the trunk and install your other dizzy with the Pertronix (or equivalent) electronic system
... and
euro911
Apr 1 2016, 09:39 PM
Well, we didn't quite get finished with the move today. Everything except a 911 motor, a 912 motor (both on engine stands) and an empty engine stand remain and we'll grab those tomorrow morning. Loaded up a T4 2056 motor in the Tacoma ... delivering it to a gentleman in Long Beach tomorrow afternoon.
My painter came by to give us a quote on the body & paint for my wife's '71 914 ('Howard', or Howie' for short). We decided to bring 'Howie' home to do a little more prepping before dropping it off with him. I need to get the local pro windshield guy to come remove the windshield and associated trim too ... I don't want to fuck up the nice brightwork pieces. I'll be removing all the rubber targa and window seals, the rocker panels and the engine compartment lid, etc. within the next couple of weeks.
Also moved my 912 home and my 911 into the Boss Hoss motorcycle storage facility. Need to get an estimate for body work and paint on the 911 soon as well. That will probably eat up a lot of my 401k
Larmo63
Apr 1 2016, 09:47 PM
I've been attending a few things on my car, new Bruce Stone pedal set installed/adjusted, new ceramic coated header pipes, various vacuum leaks and tune up performed, I want this car to be solid for the upcoming road trips to Arizona and Oregon.
I drove the piss out of it, and it seems great.
euro911
Apr 1 2016, 10:29 PM
That's a nice feeling, knowing that your car has no piss left in it
Wyvern
Apr 1 2016, 11:40 PM
Adjisted valves, (used 914 gaskets ... nice)
Changed oil.
Finished refurbishing, welding broken actuator arm, made cable nipples , and installed Flapper Boxes... and I have heat / defrost and just in time for summer ... LOL
Put in new inner window fuzzies . they were apparently a bit "tight" for the window and when I rolled down the passenger side it separated the glass from the mechanism
well disassembled the door, fixed the gasket and glass issue (Clean and good glass glue) and just bent the lip back ever so slightly so the fuzzie touches but doesn't hold.
76-914
Apr 2 2016, 07:53 AM
QUOTE(euro911 @ Apr 1 2016, 08:10 PM)
... and
I too believe that one can drive a square peg into a round hole, given enough force. One method requires a screwdriver while the other requires a tool box and an investment greater than an extra set of Petronix. Either way works, dealers choice.
Apr 2 2016, 12:07 PM
SixerJ
Apr 2 2016, 12:37 PM
Made a quick and dirty storage crate for the spare gearbox from the donor car, making sure no weight is on the speedo drive and ready to stack the -6 box on top with some minor additions
Click to view attachment Started stripping the -6
Flipped and mashed hood removed, rear bumper off, front bumper and lower valance removed plus a load of minor stuff bolted in the front boot area. Front cooler opening is as I feared, too narrow (not an issue) but way too tall for the GT cooler
Valy
Apr 2 2016, 01:41 PM
Valy
Apr 2 2016, 06:09 PM
Done.
New steering wheel finished and installed.
BeatNavy
Apr 2 2016, 06:17 PM
That looks REALLY good, Valy. Did you use that leather kit that's available?
euro911
Apr 2 2016, 07:47 PM
QUOTE(Valy @ Apr 2 2016, 05:09 PM)
Done.
Click to view attachmentWhere's the LIKE button?
Nice job Val
Valy
Apr 2 2016, 08:04 PM
QUOTE(BeatNavy @ Apr 2 2016, 05:17 PM)
Where is it available?
It's all handmade by me.
Materials are cheap, labor is about 3-4 hours of stitching.
Valy
Apr 2 2016, 08:06 PM
QUOTE(euro911 @ Apr 2 2016, 06:47 PM)
Done.
Nice job Val
Here it is:
abes914
Apr 3 2016, 06:17 PM
picked up a split window bus!
dangrouche
Apr 3 2016, 06:21 PM
Fabricated a heat shield for the relocated fuel pump. It is bolted behind the passenger seat on the firewall. I actually don't have any hot start issues or vapor lock, but made this thing in anticipation of vapor lock. I took a 3 inch diameter aluminum water bottle and cut it up and ventilated it. Actually the major heat source is radiant heat from the passenger side heat valve and maybe some heat rising from the longitudinal conduit that leads up to the passenger footwell. Sorry, the fuel pump is not for sale.
DCJosh
Apr 3 2016, 07:20 PM
Cracker
Apr 3 2016, 07:30 PM
Fantastic! Love it.
FYI: I drove my 914 home today but immediately had a problem...don't copy my mistake. In trying to locate the "primer pump" low and out of the way of the bottom of the tank - I mounted it upside down. Don't do this - they don't work upside down. I wouldn't either so I'm not quite sure why I didn't think of that. Anywho. It won't work that way...
Tony
QUOTE(abes914 @ Apr 3 2016, 07:17 PM)
abes914
Apr 3 2016, 10:00 PM
drove it everyday the whole week!
i am waiting for uncle sam to send me $$ so I can buy new tires for longer road trips.
Click to view attachmenti like my old pedal board but i can't resist a good deal-Engman pedal board from Stephen (914forme).
Thanks buddy!
Click to view attachmentClick to view attachmentClick to view attachment
Alphaogre
Apr 3 2016, 10:11 PM
Alphaogre
Apr 3 2016, 10:18 PM
QUOTE(abes914 @ Apr 3 2016, 09:00 PM)
Thanks buddy!
I like the papas and beer one! Might have to steal the from you since you are not using it any more...
euro911
Apr 4 2016, 12:12 AM
QUOTE(Alphaogre @ Apr 3 2016, 09:11 PM)
Built a new exhaust...
Nice work, Chris
Cuda911
Apr 4 2016, 12:28 AM
76-914
Apr 4 2016, 09:35 AM
Increased the overall spread of my rear stabilizer bar by 1" to clear the mufflers; reconnected my AC lines since installing a new radiator; removed and painted the front stabilizer parts.
Alphaogre
Apr 6 2016, 12:20 PM
euro911
Apr 6 2016, 12:48 PM
Those tires and wheels look awesome on your car, Chris
Alphaogre
Apr 6 2016, 02:10 PM
QUOTE(euro911 @ Apr 6 2016, 11:48 AM)
Yea thanks! I almost feel sorry for the poor sap that sold them to me and couldn't run them!
...Almost....
Dion
Apr 6 2016, 03:28 PM
Went for a shake down run after having gas tank reconditioned and obtaining proper seals for tank from Robert (rotary'14). Also a proper torsion bar adjusting bolt from Dave (914Dave). Thanks buddy.
All in prep for Hershey!
Alphaogre
Apr 6 2016, 03:30 PM
QUOTE(Dion @ Apr 6 2016, 02:28 PM)
What size lights are you running in your bumper?
They look good!
Dion
Apr 6 2016, 03:38 PM
Thanks. The yellow fogs are 5" Autoroche (France) . Cibies' on bumper are Oscar+
raw1298
Apr 6 2016, 03:48 PM
Started fiberglass work on front bumper to fit to flares.
euro911
Apr 6 2016, 04:50 PM
QUOTE(Alphaogre @ Apr 6 2016, 01:10 PM)
...Almost....
I have 3 sets of 5.5x15" ATS Classics and a nice set of 5.5x15" steelies now, so I'm good.
Glad you were able put them to use
Larmo63
Apr 6 2016, 06:36 PM
I installed this J West fog light harness that allows me to use my fog lights independent of the headlights. Also, you can flash the fogs with the turn signal stalk. I had this installed on my yellow car and I always liked it. It's super easy to install too, about a half hour job.
Garland
Apr 6 2016, 06:56 PM
Click to view attachment[/quote]
Great product, 11 years or so, still working just fine.
DCJosh
Apr 6 2016, 09:33 PM
These were waiting for me today!
euro911
Apr 7 2016, 12:04 AM
Put my Perry Umbrella Cover on the 'BB', since we've got rain in the forecast. I pulled it rearward to cover the engine lid's grille, so's it don't git wet in there
Going to start removing the last few bits on my wife's car (for paint prep), then will try to devote some time to get the hydraulic clutch release system running in the 'BB'
Cuda911
Apr 7 2016, 01:46 AM
QUOTE(Larmo63 @ Apr 6 2016, 04:36 PM)
Yep, thanks for the recommendation on this part. Installed it and am very pleased with it.
jim_hoyland
Apr 7 2016, 06:39 AM
I removed the cold start injector from the fuel lines today; not needed in So Cal. Since bypassing the CSV the engine starts faster ???o
PaulK
Apr 7 2016, 07:25 AM
Drove it, wiped,it down , took a pic, nice day.
