I've got a camping trip coming up in a couple of weeks so I decided to start prepping 'Eileen' for the event. Since I had a blow-out a couple of weeks ago, and didn't want to buy any new stock-sized 14" tires, decided to install the MBZ CLK alloy wheels and Geolander 215/65-16s on her.
I needed to install 1/4'" spacers up front so the tires don't rub on the insides, and that necessitated longer lug bolts. I just happened to have some extra 914 bolts that were blasted a while back, so I hit ten of them with flat black 'Rust Reformer'. The CLKs were previously 'altered' to accept the VW diameter and ball-seat bolt/nut profile
Click to view attachmentStarted with the front left ...
Click to view attachment... then the front right ...
Click to view attachment... then on to the right rear, but before doing so, cleaned up and painted the brake drum while I was in there
Click to view attachmentI was able to get most of the nut threads onto the stock length studs, but because the alloys are a little thicker than the steelies, and, I'll be installing 1/4" spacers in the rear as well (not that the rear tires would rub, just want to keep them in line with the fronts), I'll be ordering some longer studs (and a couple of lug nuts) this coming week.
Click to view attachmentA problem arose, though ... I wasn't able to get one of the lug nuts off of the left rear
... I sprayed PB Blaster on it and tried heating it, but that didn't work ... and when I used a longer length of pipe over the breaker bar, I ended up rounding-off the damn nut!
