I removed the rear window , and some more trim today. I think thats about all the trim. Still waiting on my new fuel pump to come in so I can drive her to the paint shop.
Cevan
Mar 31 2012, 06:02 AM
I finally got around to replacing the bushing in my pedal cluster and the accelerator cable with a nice Terry unit. My car only has 68,000 miles on it and 4 of the bushing were just completely shot. Also changed the tranny oil.
On a side note, when I removed the pedal cluster, I was happy to see nice red paint and no signs of any rust.
A quick tip if you are doing this: remove the clutch cable pulley at the tranny first. This will give you plenty of slack when reattaching the end of the cable to the pedal cluster.
Finished bleeding my brakes with nice and firm pedal, disconnected pressure bleeder, cleaned up, pressed on brakes one last time, and pedal went to the floor I'll try it again in a few days!
matthepcat
Mar 31 2012, 06:48 PM
Painted my side skirts. Fixed a coolant & exhaust leak. Installed gas tank rubbers & hold down strap that was missing. Trying to buy carpet to finish my interior. Waiting for my pedals to return so I can drive!
mojorisen914
Mar 31 2012, 07:23 PM
Replaced the ignition switch after 6 months of no start. Even went for a drive!
euro911
Mar 31 2012, 07:33 PM
QUOTE(kconway @ Mar 31 2012, 02:14 PM)
FINALLY, installed my 2.4 in my car today! Couldn't be happier.
Cool. When are you going to get it on the road? We'll have to set up another Palos Verdes breakfast run
mikelsr
Mar 31 2012, 07:42 PM
Looked at it.
'73-914kid
Mar 31 2012, 07:43 PM
Retired it as a daily driver....
Lennies914
Mar 31 2012, 07:55 PM
Primed and prepped the deck lids and doors for paint tomorrow. Hoping for good weather.
GaroldShaffer
Mar 31 2012, 08:01 PM
With my project car I finished removing the front suspension and got it up on the rotisserie. I'm in over my head, but I'm having fun.
914.SBC
Mar 31 2012, 08:28 PM
Today I said goodbye to my friend. My V8 conversion left for Arizona to a new owner. I built her in just 6 months and let her go to roam the desert. However, I am in the market for a new roller and I want to do another V8 Conversion.
So long my friend...
kconway
Mar 31 2012, 09:40 PM
QUOTE(euro911 @ Mar 31 2012, 06:33 PM)
Still plenty to do but this was a huge hurdle I was worried about for a long time. Got kinda sketchy when my floor jack started leaking while I was under the car trying to man handle it into position.
Tomorrow, weather and time permitting, I hope to run through a carb sync.
euro911
Apr 1 2012, 12:17 AM
Did a little pre-spring cleaning at the shop today. In all my haste to get the 'BB' ready for the Route-66 Run, I left the shop in a mess with tools and supplies strewn all about the place.
Removed the vinyl and foam padding from my rear targa pad, going to try covering it with perlon carpet
Also pulled some -4 rear hubs and cleaned them up ... anybody in the market for some good clean ones? Click to view attachment
I trailered my car down to 914LTD so Brad can replace my rusty floor pan & fire wall
David
Black914_4
Apr 1 2012, 12:27 PM
Changed out my fuel pump. While I was at it I relocated it. Figured the easiest place to get to it in the future was the rear wall of the engine bay. I moved the filter up there also and installed a PSi gauge.
Black914_4
Apr 1 2012, 01:41 PM
Might have a problem................
The pump is kinda noisy. Can't really hear it when motor is running (i do have a exhaust leak) But it is louder up top then it was under the car... I'll fix the leak and see how it sounds later on. Might have to move it if it's too loud after the car is fixed.
euro911
Apr 1 2012, 02:00 PM
I'd move it up front, out of the engine bay, but if not, try mounting it with some rubber dampeners to take out some of the vibration (noise transfer)
Black914_4
Apr 1 2012, 02:15 PM
QUOTE(euro911 @ Apr 1 2012, 05:00 PM)
It has a rubber sleave around it. Was going to use a couple rubber washers also but couldn't find any. I know there are threads about putting it up front. But I didn't want to have to pull my fuel tank if I needed to work it was my train of thought. Just didn't concider the pump running noise. Right now it's only an issue when motor is off.
Jeffs9146
Apr 1 2012, 04:53 PM
Finishing the paint on Lennies914's car!
JRust
Apr 1 2012, 05:05 PM
I drove mine into town to Redbox for some movies. Only a few days left on my LE on ebay. Figured I better get a few more rides in it before it is gone
bulitt
Apr 1 2012, 05:06 PM
Hit the longs with a hammer and watched the rust fall off...
DNHunt
Apr 1 2012, 05:15 PM
New fuel lines, fuel level sender gasket, filler neck gasket, and fuel cap gasket. Thanks to Mikey 914 and Racer Chris I have no more gas smell.
Dave
dlee6204
Apr 1 2012, 05:42 PM
QUOTE(bulitt @ Apr 1 2012, 07:06 PM)
I'm seeing a trend here...
pnewman
Apr 1 2012, 09:16 PM
Blasted and sprayed my window regulators with cold galvanizing spray. Cleaned up the headlight motors and di-electric greased all electrical points.
Getting as many sub-assemblies ready for my cars return from paint next week after being gone for almost 8 months! WTF!
Rand
Apr 1 2012, 09:40 PM
Removed the PO's Porsche reflector between the rear tail lights and filled all the holes left behind. Enjoyed the sheet metal work to get it flat without bondo.
Instead of reinstalling a stock push button trunk release, created a custom stealthy trunk-release solution. No chrome wart sticking out the back, just an almost invisible key slot.
Hell Yes... those cubes would be awesome in my jugmug
bulitt
Apr 2 2012, 04:30 AM
Installed Rear Bilstein Coilovers. Rebuilt a Rear Caliper Looked at the rust.............
stuttgart46
Apr 2 2012, 06:29 AM
Removed the rear decklid and started prepping the trunk for paint. Tailights out and ready to go.
EdwardBlume
Apr 2 2012, 06:56 AM
Took off the front FG bumper and FG valence. Cleaned an polished down to the original paint. Threaded and mounted studs for the valence. Working on steel turn signal covers.
Rockaria
Apr 2 2012, 08:18 AM
There is a person on Ebay selling silicone molds of the 914.
