Today was TIG day for the construction (can you say cobbling together)of two final oil line fittings / The wierd threaded one that comes out of the lower corner side of the oil tank that goes thru the engine bay metal-work......... and the AN-16 on the engine oil cooler. I mated an AN-12 fitting to each and will make up the final AN12 Braided SS hoses later today.
All oil lines are done and ready to accept oil.... Engine goes in early next week. Perry K. is making up a well coordinated engine harness to seamlessly tie into my MSD AL6 digital and other connectors and various senders etc.Cant wait to get that essential piece of the puzzle.
There is some good talent out there.
last week late, I visited my engine builder friend in LA to go over the tally sheet and to pay the piper for his sage wisdom (having built well over a hundred 911 engines in his tenure...) and to get the docs on the full rebuild bottom to top.....
so preliminary numbers are in:
core 82 3.0 / running and valve guides shot when it came out of the donner - 1000.00 not including any FI or intake but included 911 tin, fan/alt, turbo Valve covers and tensioners w/ 993 head studs installed by PO
1200.00 very solid triple Webers on PMO intake manifolds
900.00 WebCam regrind 20/21
300.00 re-curve stock dizzy to Webcam profiles etc.
100.00 Red Shroud
I tore down the engine and paid 1000 to have it professionally rebuilt with me documenting the process at every build-session. the mechanic gave me a 15% discount on parts purchased thru Pelican and his other suppliers .
parts for the rebuild included(but not limited to) Main Bearings, Rod Bearings IMS outs and inners, two one-piece timing chains,new timing chain sprockets, new rails,24 rocker shaft seals,6 piston ring sets, nuts washers engine gasket set, top end gasket set new belt, sealants, etc.
1450.00 - for parts
About 6K just for a rebuilt engine! What was I thinking?!!! I will have to drive it 300,00 miles just to get the build cost for the engine down to 2 cents a mile....
