And back to what did you do to the 914 today......
I discovered my robust firewall bushing milled out of SS for my shift rod was a little too thick and would not allow full free movement of the shift rod front and rearward. this resulted in third gear popping out of gear.
Solution was to take one half inch out of the shift rod maintaining the precise alignment of the two cone screw holes. then my pal, Keith914 came over to the shop to help me get the gears aligned with the shifter.
End result: From shifter arm bushing to side shift console bushing and everything in between - all brass, bronze or stainless steel. No slop and the action shifts like a contemporary 993 in terms of precise throws.
The 901 still has a fault code in first gear........... That insidious crunchy sound of eating a saucer of bb's (or grape nuts) is still there if I push the torque / but if I don't push it - or use 2nd for take off, everything is good to go.... and go fast.
The day before, I drained the break in oil from the tank, lines, and sump and filter. I measured what came out to be precise as to what to put back in.
The 6 took 14 qts on initial fill.
A total of 10.5 quarts came out. The front oil circuit thru the Mocal was obviously trapped.
The oil was clean and without anyindication of contamination of any sort / no filings on the magnetic sump plug and no fine screen filtered particles.
I put 10.5 quarts of fresh oil back in. I adjusted the MSD Digital up another 500 RPM's on the Rev Limiter (to 4500) / And after another 500 miles I will do the same thing and go to 6500.
