Well, Jeffery came by, we got the 'old' front trunk lid off of the 'BB and safely loaded into his SUV ... then we installed and adjusted the 'new' shiny lid on the 'BB'. Looks too nice - I'll have to wash and polish the car to match the new lid (film at 11, tomorrow morning's type 11)
We also bled the brake system and the clutch's slave cylinder. I still have to adjust the push rod on the brake pedal assembly ... too much gap due to the added thickness of the mounting bracket for the clutch's M/C.
Other items on the To-Do list:
Drain fuel tank and purge the fuel lines.
Pour in a few gallons of fresh fuel.
Install battery, attempt to start (to determine if carbs will need attention).
Drain crankcase oil.
Install new (Jonesy) Tuna Can and Taco plate.
Fill with new oil (Brad Penn 20/50).
Reinstall foot pedal plate, center armrest unit, driver's seat and driver's side carpet.
Replace faulty turn signal switch. ... and Fuse# 8.
Install new front trunk seal (914 Rubber).
Adjust headlight assemblies
Pump some fesh air in the tires and check lug bolt torque.
Test drive ...
Wash & polish exterior
Now you have no excuses, 5 weeks to knock that out.
Easy Peasy....we'll see the car there now for sure.
