QUOTE(mrbubblehead @ Apr 24 2012, 07:09 AM)
damn, i just put that same exact flywheel seal in....i hope it doesnt start leaking.
nice breather box. is that one baffled? from the guy over on the samba?
I had both, Victor Reinz and Elring seals on the shelf here, was told the Elring was better so that's what we originally installed. The
new Elring seems to have a tighter grip around the yoke on the flywheel than the one we removed, so we'll see how it works out
Trial-fit the seal on the flywheel before installation. I also replaced the graphite-coated O-ring in the flywheel.
Yes Doug, Samba. The guy's name is Travis. I had him construct the box with both, 1/8" perf and solid plate drain-back baffling. The box looks good - the welds are real nice.
Phil, it all depends on how much CCP you've got. Stock pressures may not require a remote box, but they
can be use with either carbs or FI.
