euro911
Oct 5 2017, 06:59 PM
Carter makes a ton of pumps for all kinds of applications ...
https://carter.opticatonline.com/partsThe only reason I could see the dealer stating they would need to install a regulator is if the stock F.I. (30psi) pump was retained when they installed the carbs.
QUOTE(Gatornapper @ Oct 5 2017, 05:55 AM)
My pump is a Carter as well - are all Carter's 3.5psi? PO told me the regulator needed to be installed. Since the Porsche dealer put the Webber's on, I would have thought that if a regulator was needed, they would have installed it.....
Thanks!
GN
QUOTE(euro911 @ Oct 5 2017, 01:50 AM)
I run a Carter 3.5psi pump with the 'BB (carb'd), no regulator needed ... but I used to run the 30psi pump and ran the carbs in series, then used the return line from the second carb back to the fuel tank - didn't use a regulator then either.
Gatornapper
Oct 6 2017, 08:50 PM
1. Took tank today to area's best tank restorer, will clean, de-rust, re-line & paint it with lifetime warranty for $225.
2. Ordered (missing) fuel level sending unit, gaskets from Suncoast Porsche - BTW FRIENDS - HUGE NOTE! As far as I can tell, Suncoast is 9% cheaper on parts than Pelican Parts! And their knowledge and support is superb!
3. Ordered rebuild kits for the Weber 44 IDF carbs, AND a Webber technical manual on how to properly rebuild their carbs. While I have almost 45 years experience rebuilding carbs, I can see Weber's are different and want to do it right.
Lord willing, the 914 should be running in a couple weeks.......yay!
GN
drem914
Oct 6 2017, 10:25 PM
Finally installed 914Rubber's LED headlights into my existing Ceibe lenses. Much brighter appearance. Will have to see how they look on the drive to C&C in the early morning darkness.
Now I just have to swap out the fog light bulbs and the LED swap will be complete.
JawjaPorsche
Oct 7 2017, 03:03 AM
After buffing, drove it to the liquor store!
BIGKAT_83
Oct 7 2017, 04:00 AM
QUOTE(JawjaPorsche @ Oct 7 2017, 05:03 AM)
Rabun county liquor store ?
Shadowfax
Oct 7 2017, 06:40 AM
Installed my rebuilt throttle body from Phil Eslin. Washed the car then drove it for the first time in more than a month
Porschef
Oct 7 2017, 06:58 AM
QUOTE(Shadowfax @ Oct 7 2017, 08:40 AM)
Great! What did you notice to be different? I think my TB has issues...
flat4guy
Oct 7 2017, 01:02 PM
Car show last night, short drive today and another get together this morning. Met up with another crazy paint friend.
euro911
Oct 7 2017, 01:12 PM
Hand doctor appointment yesterday am ...
FedEx delivered another new guitar as soon as I pulled back into the driveway ...
UPS delivered a new car cover for the Ghia, so I could put the 'BB's cover back on the 'BB' ... need to locate my California Car Duster first (where did I put that thing)
Didn't perform any additional 914 activities for the remainder of the day ...
... but love the new axe
SKL1
Oct 7 2017, 10:22 PM
Porsches and Pancakes today at Anthem Country Club, just north of PHX... only 2 AC cars and only ONE 914...
Click to view attachment Click to view attachment
Larmo63
Oct 7 2017, 11:34 PM
I drove the car up the coast to my parent's home in Newport Beach, and what a wonderful drive. I got a lot of thumbs ups, smiles, and looks. You just don't see 914s on the road anymore. Came home, put the car on jack stands just to do some inspection, no oil leaks, but I did do a bit of cleaning. Everything looks tight and proper.
Gatornapper
QUOTE(euro911 @ Oct 7 2017, 01:12 PM)
Ok, Mark. You know you won't get away without telling us about the axe.....you gotta know others here play and absolutely NEED TO KNOW ALL ABOUT IT!!!
BTW, been playing Martin's since 1970 when my first one was a 1939 D-18......a year ago just picked up a custom-made very unique 000-28H from Martin's CUSTOM SHOP that is now my first-love - a 000 version of the HD-28. Best sound & action of any acoustic I've ever owned.
No electrics like my old JC-16RGTE in rosewood I sold.....don't need electrics anymore as I pretty much play for myself. Still have my '74 D-1228 I've owned since 1975 - in mint condition since total resto by one of Martin's best luthiers...
GN
Gatornapper
Oct 7 2017, 11:38 PM
Pretty much finished rebuilding the left carb (Weber 44 IDF) last night - looks like new - just need to set the float and put in new gaskets when they come later in the week.
Will start on right carb sometime this week.
Can't wait to hear this baby purrrrr.......rrrrr......rrrr......
GN
euro911
Oct 8 2017, 05:46 PM
QUOTE(Gatornapper @ Oct 7 2017, 10:34 PM)
GN
Yep, there are a lot of good guitar players on this forum and the subject has been discussed many times over the years. Perry Keihl started a thread a month or so ago where some folks had posted pix of their gear. Martins and Taylors were discussed a bit.
I picked up a Thinline Telecaster this go-around - been wanting one for years because they're so light weight. This one is only 6 lbs ... my '72 Tele with the Bigsby tremolo weighs in a tad under 10 lbs.
I mostly play rock, but some jazz.classical fusions as well. At 63, recently recruited some younger guys to start up a new band. I hadn't played in a band since the 70's
... hope I can keep up with them
Did a little fine-tuning on the saddles yesterday and quite happy with new new acquisition ...
Gatornapper
Oct 8 2017, 05:58 PM
Mark - SWEET!!!!! & beautiful! does it play as good as it looks?
An acoustical guy myself, 72 - and no, I cannot keep up with anyone younger unless they are beginners.....
Always wanted to add a Taylor to my collection, but at my age cannot justify it - don't play what I have enough already........
GN
QUOTE(euro911 @ Oct 8 2017, 05:46 PM)
GN
Shadowfax
Oct 8 2017, 06:38 PM
QUOTE(Porschef @ Oct 7 2017, 07:58 AM)
There is no more gap between the plate and the body. The throttle response seems smoother but I can’t really tell much difference when driving. Looks nice too
jim_hoyland
Oct 8 2017, 06:45 PM
QUOTE(Shadowfax @ Oct 8 2017, 05:38 PM)
Phil does great work; he did my larger Vanagon TB and it’s great. Make sure you have a new TB gasket
euro911
Oct 8 2017, 06:55 PM
I forgot your wife has a Vanagon, Jim.
I think I finally traced down and fixed an intermittent ignition electrical gremlin on ours. It would run fine for months, then it would just stop running out of the clear blue. Found a suspicious wire connection at the (-) side of the coil ... cut it back an inch and crimped on a new slide-on connector.
I took it off the market due to the problem. Hope this fixes the issue for good.
76-914
Oct 8 2017, 07:24 PM
Adjusted the L post on the engine lid. It had begun to pop open on bumpy roads when under hard acceleration.
This thread might need a Title change, soon.
iamchappy
Oct 8 2017, 08:39 PM
Changed out the ra 1 tires for the conti extreme contact all season tires, and went out and flogged it....love the crisp air and turbo..
Larmo63
Oct 8 2017, 09:12 PM
I have quite a few guitars around here, but the #1 player is a 00-18V that won the Martin sweepstakes. I had about seven of them here at one point, but I whittled it down a bit. This one just sounds and plays the best. I play every night before going to sleep. Today I was out on the front steps playing to my hearts' content.
I'm too far past caring what anybody thinks about what I play and sing.
euro911
Oct 8 2017, 10:23 PM
For Kent ...
I think Dianne's is one of those white ones
Mueller
Oct 8 2017, 10:50 PM
Just cleaned up in the garage, I did find a review on Amazon that the person mentioned using the product on their 914:
By CMM on September 27, 2017
I'm using a 2,600 psi 2.6GPM pressure washer and Multi-purpose sand from Home Depot. The sand is pretty fine, dry and clean. The problem I'm having is the sand doesn't flow consistently. It flows for lack of a better word, in chunks. I can see maybe 2-3" chunks of sand making its way down the tube and then BAM! It blasts out and does remove the paint from a car I'm restoring. So it works, but takes REALLY long to strip an area. I've tried playing around with the flow control, doesn't seem to make any difference. Honestly, I have it closed and seems to work better in that position. I do zip tie the hose to my wand so its on top. In 1.5 hours of blasting I went through four 50lb bags of sand and only cleaned maybe 60% of a Porsche 914 engine compartment. Pretty small area. And be aware, its EXTREMELY messy. When finished sand will be EVERYWHERE and you will get flash rust on bare metal almost immediately. I've decided to use it for the hard to reach places and Aircraft paint remover for the larger panels. Maybe a larger pressure washer is the trick. I'm just too cheap to rent one not knowing if it will make a difference.
914 Ranch
Oct 9 2017, 07:54 AM
Posted a picture of her in the Paddock.
Carerror
Gatornapper
Oct 9 2017, 08:03 AM
Lawrence....
Pics - pics - pics. Gotta see that 00-18V......what year is it?
TOTALLY agree with your last sentence.....
A good motivation for me to playing more like you do 'on the front steps'......
GN
QUOTE(Larmo63 @ Oct 8 2017, 09:12 PM)
I have quite a few guitars around here, but the #1 player is a 00-18V that one the Martin sweepstakes. I had about seven of them here at one point, and I whittled it down a bit. This one just sounds and plays the best. I play every night before going to sleep. Today I was out on the front steps playing to my hearts' content.
76-914
Oct 9 2017, 08:32 AM
QUOTE(914 Ranch @ Oct 9 2017, 06:54 AM)
Carerror
That's got to be a kick in the ass to drive. What's your P to W ratio?
914 Ranch
Oct 9 2017, 09:12 AM
Kent, I am disappointed with the numbers, I thought it would be kool but no.
1:8, it's about 200 hp in 1600 #.
8:1 don't sound any better.
I tried to fit the new accelerator cable but that never happened!
I did however fit the clutch & Speedo cables. In doing those 2 I found I have 2 leaky pushrod tube seals.
Chris Pincetich
Oct 9 2017, 01:50 PM
Today I drove it, like always
This weekend I re-painted the top and replaced the sail panel vinyl. After a long hiatus of just driving my 914, I am back to working on it and improving it. Parts that were stored for months are going on! And, sadly, in a few weeks I'll post a bunch of pictures in my future ad in the Classifieds as it's time to end this 12 year relationship and sell the 914.
914 Ranch
Oct 11 2017, 11:49 AM
Cleaning the interior and the carbs.
Click to view attachmentFar one is clean and the other is not.
jim_hoyland
Oct 11 2017, 02:19 PM
Today Pioneer Leather made a House call to refinish my leather GTS Le Mans Driver seat. Fun to watch how they refinish leather and learned a few tricks when cleaning upholstery.
The tech first cleaned all the dirt and grim with a 1:1 solution of isopropyl and ammonia. The grime just flowed out. He applied the cleaner with a spray bottle and gently worked the leather with a Mr Clean Magic Eraser; then mopped up with a microfiber towl.
After cleaning and drying, he sprayed the dye on.
jim_hoyland
Oct 11 2017, 02:21 PM
Picture of Mr Clean Magic Eraser. Also good for vinyl
euro911
Oct 11 2017, 03:50 PM
My driver's seat could stand a good refreshing, Jim. How much did they charge? ... (you can PM or call me if you don't want to spill the beans)
Gatornapper
Oct 11 2017, 04:52 PM
WOW! Love tan interiors.....
QUOTE(jim_hoyland @ Oct 11 2017, 02:19 PM)
arne
Oct 11 2017, 08:02 PM
Sold it. Time to start hunting my next project!
Gatornapper
Oct 11 2017, 08:05 PM
Can we ask what you got for it? All original? Mods?
GN
QUOTE(arne @ Oct 11 2017, 08:02 PM)
SO.O.C914er
Oct 11 2017, 08:21 PM
Seats look great Jim
you always have the good connections for sure. Hey I will be dropping my car off at PCH garage tomorrow 5pm if you want to stop by for some bench racing
euro911
Oct 11 2017, 09:38 PM
Thanks for the info, Jim ... I'll give 'em a call
SKL1
Oct 12 2017, 04:37 PM
Love that picture of the 914's I assume at the Karman factory way back when... maybe my '71 is in there somewhere!
Took the '73 out for a cruise and gave it a present of some 95 octane fuel...
DaveO90s4
Oct 13 2017, 04:29 AM
Hell hole rust repair complete. New engine tinware all but completed. Completely new engine mounts fabricated and installed. 2.8 L reverse rotation Corvair engine installed (again). Throttle linkage fabricated. Can nearly see the light at the end of the tunnel. Hope to be driving it this time next month.
76-914
Oct 13 2017, 08:13 AM
QUOTE(jim_hoyland @ Oct 11 2017, 01:19 PM)
Very, very nice Jim. You always make a beautiful 914 look better than the last time I saw it.
914 Ranch
Oct 14 2017, 09:07 AM
Cleaned the interior and now that my carb kits have arrived I can finish the carbs.
Bonkers is watching me.
JFG
Oct 14 2017, 09:23 AM
Finished figuring out the twin carb linkage and fitted that. Gave it a bit of a review on the drive. It's loud!
Ordered the cable bracket from mark.
Took off the last rear caliper in readiness to refurbish them both.
Realised I actually like the look of the steel wheels and may keep them instead of the Riviera's that have. Although one steel is wider than the others so will need to find another to match.
euro911
Oct 14 2017, 10:47 AM
QUOTE(DaveO90s4 @ Oct 13 2017, 03:29 AM)
When you change the engine's rotation, do you install the pistons 180° from normal?
arne
Oct 14 2017, 11:14 AM
QUOTE(euro911 @ Oct 14 2017, 09:47 AM)
I researched this years ago when contemplating building an Abarth clone based on a Fiat 600. The 850 motor is essentially the same but reverse rotates, so you have to convert it when mating to a 600 transaxle. You need a reverse rotation camshaft, and ideally the pistons should be turned so the thrust angles are correct. Many people in the Fiat world don’t turn the pistons and get by that way, but wear is increased.
moe
Oct 14 2017, 07:39 PM
Installed 914 rubber shifter bushing kit.
Mueller
Oct 14 2017, 08:13 PM
Bought a media blaster kit to hook up to my pressure washer....
I am using baking soda for the media.... 1st test and it works pretty darn good, just messy (more so the water spraying back at me ) I'll have to fix that!
There was a lot more build up between the webs before I gave it a blast. Just plain water out of the gun didn't do squat.
euro911
Oct 14 2017, 08:46 PM
Looks good, Mike. Which pressure washer and blaster kit did you get?
Mueller
Oct 14 2017, 09:01 PM
QUOTE(euro911 @ Oct 14 2017, 07:46 PM)
At 1st it didn't suck up the soda very well, once I added some tape to the where the water wand hooks up to, it made a huge improvement since it works on venturi principle
Cheap Lowes gas pressure washer, 2600psi and 2.6gpm.
MTM Hydro 16.0117 5000 psi Industrial Sand Blast Kit from Amazon
michael7810
Oct 15 2017, 06:50 PM
Need to ease my daughter into the idea of the granddaughters riding in the 914. It was only a pretend ride but they loved being in Pop’s Green car.
