Dec 1 2017, 03:00 PM
Opened the garage door and looked at her ...
I should probably try to fire her up this weekend, she's been sitting for months.
SKL1
Dec 1 2017, 04:29 PM
Taking the '73 to a C&C at a Porsche themed coffee shop in Old Scottsdale tomorrow morning. Supposedly a lot of AC'ed cars show up- will see how many 914's... maybe MoveQik?
Place called Fourtillfour (get it??)
anderssj
Dec 1 2017, 06:10 PM
QUOTE(SirAndy @ Dec 1 2017, 05:00 PM)
Same, same . . . well maybe by Tuesday anyways
cary
Dec 1 2017, 11:52 PM
Spent the first couple hours labeling my new bulk hardware bins. Then on to getting Mike's (Warpig) car ready for Saturday.
Finished installing the fuel pump harness into the fuel tank cavity. Thru the firewall with a solid grommet with a slit in it to allow the harness to go thru.
Click to view attachmentThen I installed the fuel pump.
Click to view attachmentSeam sealed the hell hole with brush on seam sealer. Then coated it with the first application of Eastwood HD Anti Rust.
I mounted the remaining heat exchanger & muffler, going to have to reshape the heat shield as I must have kinked or twisted it when removing.
I'm going to need to get a new clutch cable as this one seems to be stretched. I'm also going to have to replace the brand new hemp accelerator cable as the thread that holds it in place in mcmarks bracket snapped with just one light nip with a spanner.
Because I was on my own today and needed to turn the car around and the only way was to speed up the idle and limp it around, does this count as the first ever time driving it?
SKL1
Dec 2 2017, 08:20 PM
C&C in old Scottsdale. Only 914 there but lots of AC'ed cars including a bent windshield pre A, and a great backdated SC coupe done by Patrick Motorsports... Even sprinkled for a few minutes and had to put the top on!!
Click to view attachment Click to view attachment
914 Ranch
Dec 3 2017, 03:53 AM
Working inside the box. The work that I do usually doesn't fall in that category.
914 Ranch
Dec 3 2017, 03:57 AM
Another picture just for me.
Click to view attachmentRaw beauty...
Craigers17
Dec 3 2017, 11:58 AM
Cleaned up internal door locking mechanism, lubed, and installed ...nice, easy task.
Then, sanded down trunk and right door sill area with 80grit and some rust dissolver.
Rattle canned the trunk with primer....will need to sand a few "dirty" areas again such as you can probably see on the driver's side shock tower sheet metal area.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=630
103]
StratPlayer
Dec 3 2017, 01:19 PM
Installed new Rockford Fosgate speakers then put the car away for the winter
I fitted the last caliper on the rear today and I have now started to get brake on the car. More bleeding and adjustment on the pedal to get it right I think.
However I found one of the pushrod tube seals is now leaking
New (used from bdstone) suspension arm to be fitted on the front tomorrow.
porschetub
Dec 3 2017, 04:07 PM
Gave the old girl a clean,test drive after lowering the front 20mm and managed to dust it up again
,we are heading towards a drought and very hot here @ the moment,decided not to drive it anymore as its too dusty on my entrance road and I'am commiting to painting my house before the new year as I have friends coming from Australia.
Off to the North Island to see my kids for Xmas so that will be great.
Click to view attachment The pic of my Audi gives an idea of the dust on the road,I have to hose it down every couple of days....so much for living in a piece of NZ paradise ,never mind shouldn't complain.
Click to view attachment.
Larmo63
Dec 3 2017, 06:43 PM
We met this morning and drove down to the Porsche swap in Escondido. The swap was a bit of a dud, but any excuse to go exercise the car. Autos International had an open house too, so we did get a brief tour of their facility and I was able to discuss my interior needs with Augustin. As we drove up to the event, Coondog was driving in from the other direction driving his new 3.0 conversion just back from PMS. Great build. Sounds glorious!!
We also met up with Jim - Lucky9146, and he invited us down to his house to see his ongoing build. Wow!! He's hiding some great cars!! He is a very talented man indeed.
Cars parked in the driveway to give him some 914 inspiration.....
Lucky9146
Dec 4 2017, 12:50 AM
QUOTE(Larmo63 @ Dec 3 2017, 04:43 PM)
Click to view attachmentParticipated in the above mentioned Porsche dud swap meet to help fund my addiction, but the best part of the day was hanging out with these guys! Not often one sees three 914's out in front of their house, at least for me! And,it was inspiring to see actual running driving 914's.
It's coming!
euro911
Dec 4 2017, 01:15 AM
Went through both garages and located some 'P' parts that I'll be bringing back to CA.
Other than that, just doing some yard maintenance since I hadn't been to the AZ house for almost a whole year
Click to view attachmentAnd goofing off playing guitar in the evenings
914 Ranch
Dec 4 2017, 12:58 PM
Worked inside the box today. Had a chance to close it and took a picture.
Elliot Cannon
Dec 4 2017, 01:11 PM
QUOTE(SirAndy @ Dec 1 2017, 01:00 PM)
To be clear, you're talking about the car right?
mb911
Dec 4 2017, 01:26 PM
I fit some heat exchangers to our new muffler for trial fittment
MartyYeoman
Dec 5 2017, 12:16 AM
Put the finishing touches on my 2056 L-Jet. Can't wait to run this one. It's been 5 years in the making.
ndfrigi
Dec 5 2017, 01:19 AM
Replaced injector seals, installed front and rear tins. Next Replacing new fuel rubber lines, installing SS tunnel fuel lines, installing fuel pump. 74 1.7 Sunflower car of a member here that I’m helping.
914 Ranch
Dec 5 2017, 07:15 AM
First of all I would like to thank Doug and Andy. Doug for this thread and the quote about eating elephants and Andy for this site and teaching me to take pictures.
Click to view attachmentIn the picture above the dry box is closed and all the circuits are on and no blown breakers... Man she's gunna be so fast it shows in pictures.
euro911
Dec 5 2017, 12:38 PM
QUOTE(914 Ranch @ Dec 5 2017, 05:15 AM)
Click to view attachment...
RickS
Dec 6 2017, 06:23 PM
Because I am a total tard and cannot get the used to the slightly off to the right 2nd gear location due to the side shifter on the 6, I always ground the gears if I stopped paying attention and thought I was driving a normal manual like my other 2 cars. So I built a quick and dirty blocking tongue using 3” PVC pipe cut 2.5” in length with a cap cut with a tongue to keep me going into second rather the space between reverse and second. Works great and cost $6. It’s anchored with a couple of L brackets. When covered, my abomination of a hack job is out of sight. Looking at the pictures, I am a tard and a hack.
914 Ranch
Dec 6 2017, 11:53 PM
QUOTE(RickS @ Dec 6 2017, 07:23 PM)
Click to view attachment Click to view attachmentWhat ever works...
Jett
Dec 7 2017, 12:29 AM
Getting closer... there were four 914’s in the shop
RickS
Dec 7 2017, 09:44 AM
QUOTE(Jett @ Dec 6 2017, 10:29 PM)
Which shop?
914 Ranch
Dec 7 2017, 11:51 AM
Took pictures. Everything thing up here works now on to the engine bay.
914 Ranch
Dec 7 2017, 11:53 AM
I took the front sway bar off entirely and cut the reinforcement channel to gain inner fender access for the repair and strengthen the weak and damaged area around the sway bar mounts.
I made some templates and fabricated 4 plates to weld in on both sides. I've got a day off tomorrow so I'll weld them in then. Hopefully my new bushes and cables will be here tomorrow.
gerber28
Dec 7 2017, 09:48 PM
Finished the vinyl wrap on the 914. Used 3M 1080 film. Not as good as a new paint job but for less than $400.00 in vinyl it's a great improvement, even if it is temporary.
RickS
Dec 7 2017, 10:00 PM
Looks fantastic from where I sit. You should have your own ‘how to’ thread.
914Sixer
Dec 7 2017, 10:14 PM
Christmas bling arrived today. Restored 2.0L distributors. Ready to go top to bottom. Set to factory spec on Sun distributor machine.
euro911
Dec 8 2017, 12:40 AM
QUOTE(gerber28 @ Dec 7 2017, 08:48 PM)
Yah ... looks great
Tbrown4x4
Dec 8 2017, 03:50 AM
That vinyl wrap looks great. I should get some in camo and do the parts car so my wife will stop griping! haha
napasteve
Dec 8 2017, 09:23 AM
Drove to the gym and grocery store. First time out since our October fires.
Welded in the passenger side reinforcement plates that i made yesterday for the front sway bar.
Received my new sway bar bushes, accelerator & clutch cables from rose passion.
SKL1
Dec 8 2017, 03:03 PM
Installed Vacca's shift knob on the '73. Looks great!
(napa- what colour blue is your 914? Have to admit, I could never park mine like that- I'd be so paranoid for a door ding...)
napasteve
Dec 8 2017, 03:34 PM
SKL1- it's Olympic Blue; original paint I believe except for passenger rear fender repaint. The paint looks good from 15' but there are lots of dings so I don't worry too much about parking. I do try to leave as much distance as possible from other cars.
mlindner
Dec 8 2017, 04:17 PM
Installed new strut tower bushing from 914rubber. What a nice product....Best, Mark
ndfrigi
Dec 8 2017, 08:04 PM
Installed elbow rubber fuel lines on injectors and other FI parts to a member 1.7 engine.
RickS
Dec 8 2017, 09:16 PM
Removed ignition cut-off switch (anti-theft) because it was doing its job so effectively, even I couldn’t steal it with the key (the guts fried due too great a current load). Worked great for 3 years and then random cutouts followed by death. Real exciting at 70 on the interstate- everything quits.
poorsche914
Dec 8 2017, 09:33 PM
Drove home from work in first snow of the season in east Tennessee.
Finished welding and tidying up the reinforcement plates on the passenger front side.
I need a new master cylinder as mine has leaked into the pedal cluster
Now turned around ready for welding the drivers side and to replace a pushrod tube seal.
hot_shoe914
Dec 9 2017, 05:02 PM
I brought home #6, which makes 7 in the shop now.
Shoe
sb914
Dec 9 2017, 05:53 PM
QUOTE(hot_shoe914 @ Dec 9 2017, 03:02 PM)
Shoe
Obviously you have a problem!
ndfrigi
Dec 9 2017, 05:54 PM
installed Allan’s fuel pump on his 73 1.7 djet.
raynekat
Dec 9 2017, 06:04 PM
Awesome pic and use of your teener.
QUOTE(poorsche914 @ Dec 8 2017, 07:33 PM)
lonewolfe
Dec 9 2017, 06:40 PM
Click to view attachment Where do you live? I grew up in Chattanooga.
Mikedrevguy
Dec 9 2017, 08:43 PM
Windshield is installed. Now the rear trunk.
76-914
Dec 9 2017, 09:19 PM
Fired up #3.
