Zinc with a "c" please
I knew someone on this board was smart!! Thanks
PS: I read that you can remove the zinc by putting it back into a solid form by plating something until there is no more free zinc floating electrons remaining in the bucket. And as long as your acididic solution is vineger, salt & sugar it is not an environmental hasard!? I have not confirmed this but thats what I read!
From the educational web page:
The Experiment is done: now, Waste Disposal!
In the "real world" waste disposal is a major headache for electroplating factories. But here you have only used toothpaste, vinegar, salt and sugar. The very small amount of zinc or copper you have dissolved into it is really not a significant issue. But let's learn to practice environmental responsibility, rather than learning to talk ourselves out of it! So, with the wires disconnected, put a good size chunk of Steel Wool [link is to product info at Rockler] into your bowl of plating solution. Any copper, and some of the zinc, will "immersion deposit", plating out onto the steel wool, thereby removing the waste from the solution. Copper metal is not a pollutant, but dissolved copper is. Good luck!
