QUOTE(trekkor @ Aug 21 2004, 06:56 PM)
The carbs are off the motor and in my shed now.
I'll break 'em down in the next day or two.
Has anyone ran into problems that baffling fixed?
I'll do it if I need to- only if I need to.
rebuilding: do one side at a time. there are places where it can be really handy to have one done right to compare to ...
baffles: there are two approaches on race prep. one says do everything you know about when it's convenient because it will never be easier and then you'll -know- you're ready, and you won't lose an event due to something left undone - especially, if it's something you knew about and decided not to do.
the other approach says there is never enough time nor money to do everything that needs doing, so first concentrate on the places where little investments have big payoffs -- the "low-hanging fruit." then address the things that need addressing when they rise up the priority chart.
'best' is probably somewhere between. i never needed a baffle fix for fuel starvation - but i never AX'd my /6 on slicks, and the street tires available to us then were nothing like today's. JP's said he's never seen a starvation issue, and he's running both slicks -and- a big engine. but maybe the courses available to him don't have the kind of long, high-g sweepers some of the CA courses have.
you won't know if you -need- it until you start dropping a bank on a long, tight sweeper. if that costs you a class win, you'll be pissed. are you running within a tenth of the class leaders now ?
my guess is you won't -need- it until you've got the rest of the car sorted and have learned to drive to maximise its potential - by which time, you'll probably be ready to take the tops off again - maybe to adjust the float levels (do you have the sight gauge ?)
