Setting up Nelson's steering and find this. The shaft is too short.
How can that be? The suspension is all bolted up where it goes.
Dec 21 2011, 12:05 PM
QUOTE(Series9 @ Dec 21 2011, 10:04 AM)
Setting up Nelson's steering and find this. The shaft is too short. How can that be? The suspension is all bolted up where it goes.
It doesn't look like it's bolted up correctly. That rubber doughnut needs to come up much higher through that hole.
Did you install rack spacers? Did you forget the rearward bolts on the tabs for the steering rack? They need to be seated correctly.
Dec 21 2011, 12:07 PM
How about a pic of the other side of things?
BajaXJ92
Dec 21 2011, 12:08 PM
QUOTE(Series9 @ Dec 21 2011, 01:04 PM)
Sorry to hear, Nelson.
ruby914
Dec 21 2011, 12:09 PM
Is that shaft a different length on a 911 compared to a 914?
Dec 21 2011, 12:16 PM
QUOTE(ruby914 @ Dec 21 2011, 10:09 AM)
Yes, it is. But that doesn't explain why the rubber doughnut does not come up far enough.
Cap'n Krusty
Well, it has a different part number, indicating there's a difference of some kind.
The Cap'n
Series9
Dec 21 2011, 12:43 PM
I'm sure I'm going to feel stupid when someone points out what's wrong, but sometimes you can't see for forest for the trees.
These are the exact same parts that were removed from the car.
The bolts in the rack are loose because I'm looking at this problem.
Dec 21 2011, 12:54 PM
All the bolts need to be tight, including the two i marked in the pic.
KELTY360
Dec 21 2011, 12:59 PM
That's what she said.
Series9
Dec 21 2011, 01:16 PM
QUOTE(SirAndy @ Dec 21 2011, 01:54 PM)
They were. I pulled them out to mess with it. Trust me, that's not it.
But, just to be sure, I just put in all the bolts and tightened them up. No change. This thing is like 1.5" out of place.
sixnotfour
Dec 21 2011, 01:38 PM
captn's right you have a 911 shaft.
ruby914
Dec 21 2011, 02:38 PM
How long is your shaft?
montoya 73 2.0
Dec 21 2011, 02:45 PM
QUOTE(BajaXJ92 @ Dec 21 2011, 10:08 AM)
This thread went bad in a hurry!
Madswede
Dec 21 2011, 05:59 PM
QUOTE(BajaXJ92 @ Dec 21 2011, 11:08 AM)
Dayum. Just got I'll remember this when the car's done!
SLITS
Dec 21 2011, 06:13 PM
O'brien ... the bearing is in the correct location ... a plate goes over it. And inside that rubber you will find a caged roller bearing.
There is a length difference between the input shaft of a 911 and a 914 and I don't remember which one is shorter. I just use a 914 rack with the 911 suspension.
Series9
Dec 21 2011, 06:48 PM
These are the parts that were driving this 914 when it arrived. I need a better explanation.
BMITCHELL
Dec 21 2011, 06:55 PM
Did you have another rack out from a 911 at the time? Parts get comingled?
jimkelly
Dec 21 2011, 07:00 PM
the answer is under the plastic cover : (
ellisor3
Dec 21 2011, 07:12 PM
Joe, When I was there, I left you a steering rack I had left over from my project. Maybe they got mixed up. I am 99% certain it was a 914 rack though.
Series9
Dec 21 2011, 07:16 PM
QUOTE(ellisor3 @ Dec 21 2011, 08:12 PM)
Holy crap. Maybe that's it.
More tomorrow......
scotty b
Dec 21 2011, 09:47 PM
I know you said this is the rack that came out of it, BUT just to reinforce the fact that they have different shafts.......
scotty b
Dec 21 2011, 09:49 PM
nudder
BajaXJ92
Dec 22 2011, 05:37 AM
Is that one of the 914 racks I gave you Scott?
sixnotfour
Dec 22 2011, 05:51 AM
The Cap'n
Doesn't get much better, But A picture is worth a thousand words
Carry On, put your short shaft where it came from and put the longer one back in
More tomorrow......
Makes sense Joe, I purchased a complete 911 front end, but I would have had to use my (MUCH LONGER) 914 shaft, and I probably attached the 911 one to the old 914 rack.
rnellums
Dec 22 2011, 06:28 AM
I think it must be 911. The location of the raised shoulder for the rubber vibration damper is too high on the shaft for 914.
Series9
Dec 22 2011, 07:47 AM
That has to be it. I forgot that James gave me a rack. I'll go over to storage in a little while.
Nothing like a little public stupidity to keep me humble.
SLITS
Dec 22 2011, 08:18 AM
QUOTE(Series9 @ Dec 22 2011, 05:47 AM)
As a Class A raving lunatic, there is no need to be humble. You have a "Hall Pass".
76-914
Dec 22 2011, 09:32 AM
No way. My dad always told me that the three smartest words a man can say is "I don't know."
Series9
Dec 22 2011, 10:13 AM
That was it.
Can we erase this thread?
Thanks guys.
BMITCHELL
Dec 22 2011, 10:41 AM
I think this is a good lesson for the guys swapping out their suspension.
Series9
Dec 22 2011, 10:43 AM
QUOTE(BMITCHELL @ Dec 22 2011, 11:41 AM)
Rav914
Dec 22 2011, 11:16 AM
While you're there......
Replace that stock coupler with a solid one (I can't tell from the picture but you may have already). Really a great improvement IMO.
Madswede
Dec 22 2011, 01:04 PM
QUOTE(Series9 @ Dec 22 2011, 06:47 AM)
Looks like you need a better parts inventory tracking system.
Chris Pincetich
Dec 22 2011, 03:10 PM
Short shaft problems should stay on the board, as I am sure others are seeking advice on fixing their short shaft
Isn't there a better joke in here somewhere? "What do 911 owners have in common with their steering rack?"
Rob-O
Dec 22 2011, 09:21 PM
I vote classic!
sean_v8_914
Dec 23 2011, 08:01 AM
solid mounts are evil satanic plants into the holy sanctity of the blessed garage
