The outboard one. I am trying to tighten it before installing the entire trailing arm back in the car. Becasue on the test fit. There is no way to access the screw to tighten it. It is too close to the side rocker panel. I was tightening it with my 1/2" gun, should I worry about over/under tightening it to the 104 ft lb ?
Any tips ??
As far as the inboard one, looks like I need to remove the heat exchangers to get my socket on it right ?
