Evill Ed
Apr 30 2003, 08:24 PM
Hey, I just finished installing BMW 320i calipers on the rear of the 914. I added a Tilton proportioning valve too. In the front, I have vented 911 rotors with M style calipers. They are actually BMW units, not 320i, for a 5 series with vented rotors. The Pistons are a little larger than M pistons.
Anyway here is the deal. My front brakes lock up way before the rears. When braking moderately, with the propotioning valve set in position 5 (of 7) the car pulls down tightly and evenly. If I brake hard, the car starts to slow evenly, but then the fronts lock and skid. If I go to max position on the proportioning valve, when I brake heavy at higher speed, the rear gets light and the nose starts to turn to the right. then the fronts lock.
The right front locks faster than the left. The fronts have always locked like this. I figured the stock rear 914 calipers were too small and kinda beat, even with rebuilds, so I went for the 320i's.
The 911 19mm master is new, the brake lines are new rubber, all calipers are rebuilt and perfect, and the system is bled well.
I'm begining to think this may be related to weight transfer from front to rear.
The front is 21mm torsion bars with a 19mm Weltmeister sway bar with Weltmeister soft bushings.
The rear is 140# Weltmeister springs. Front and rear struts are Bilstein.
Should I go to 165 or 180# rear springs?
Am I on the right path?
I appreciate any input.
Regards,
Ed
ChrisReale
Apr 30 2003, 08:34 PM
I think 21mm bars equal roughly 175 lbs in spring weight. So, you have 175# up front and 140 rear. I would go to 180 rea if you keep the 21mm bars, but then, you might want to upgrade to a 22mm bar??
Evill Ed
Apr 30 2003, 08:40 PM
Thanks Chris. I have a 22mm sway bar too. I had changed to the 19mm becuase the front used to plow really bad. (That right there would indicate that the front is too stiff huh? )With the 19mm, the car would turn.
If I recall correctly, the front brake lock ups started after I went from stock torsion bars to the 21mm.
Anyone else?
Regards,
Ed
drew365
Apr 30 2003, 09:26 PM
The fact that your right front locks and pulls seems to indicate you still have a brake problem. Maybe a pinched line steel line? After I put 22mm torsion bars on my car I had big time understeer until I upgraded the rear springs but my brakes didn't lock up in front.
Brad Roberts
Apr 30 2003, 09:33 PM
Ed..
I'm still taking all this in. Weight transfer happens evenly "normally" so the right front locking up shouldnt have anything to do with the weight. Are the shocks in good shape ?? A bad shock that is screwed up on the rebound side... *might* cause something crazy.
I'll be honest here... this sounds like a rubber brake line problem straight out of the gate.
B
ChrisReale
Apr 30 2003, 09:35 PM
Yea, I was thinking that you have a pretty wickid car, but rubber lines...
Maybe an upgrade to steel lines?
Brad Roberts
Apr 30 2003, 09:40 PM
The rubber ones work fine... but they can rip on the inside. Especially if you have done a ton of bleeding and possibly passed something thru the system.
Thinking more on it.
One of the pistons in that right front caliper has an issue. Like the piston is worn or you installed a rebuild seal incorrectly ?? Any of that sound possible ?? Did the caliper have any rust pits in the cylinder bore ?
B
ChrisReale
Apr 30 2003, 09:42 PM
Exactly, they work fine, but they can rip...
airsix
Apr 30 2003, 10:01 PM
If your corner ballance is way off could it cause said condition? ie most weight on an opposing front and rear wheel causing the unweighted front wheel to lock first? All the weight transfer of heavy braking probably overshadows the comparatively small effects of corner ballance, but I'm just brain storming.
-Ben
ps - Ed, how much advance are you running under boost? I'm just looking for some benchmarks. (I'm getting closer)
Brad Roberts
Apr 30 2003, 10:11 PM
He could have it off (balance) but it would be obvious in the rear shock collars or the front torsion bar adjusters. It would take a one inch plus off balance to make a difference. More than visible by the naked eye without measuring it.
B
john rogers
Apr 30 2003, 10:17 PM
If the calipers are rebuilt units I would suspect they haven't seated in the seals yet or one could be bad? Are the pads good and free in the caliper? Are the calipers aligned exactly to the rotor, both axially and parallel? I agree with Brad, chack the shocks to see if one is failing which could cause the side locking. If the fronts are locking then there is not much braking in the rear it seems and I would try to get somemore brake use from the rear calipers. Are you running out of brake pedal travel or close to running out as there might not be enough fluid volume to go to the rears? You might need one of the 23mm m/c and I had to use one when I pur 320 calipers all around on my race car? Good luck
Qarl
Apr 30 2003, 10:18 PM
Chris... interesting info about matching the spring rates to the torsion bars? Do you have any additional information about torsion bar rates and spring rates. What about solid vs. hollow.
I'm putting together my suspension for my street 914-6 GT car right now.
Here's what I have....
Front:
Carerra front end with undermount swaybar and aluminum cross member.
I am probably going to get rid of the undermount bar and put on a Smart Racing swaybar. Brad says 27mm, but I'm wondering if that's too agressive for a street car.
22mm solid torsion bars up front.
Bilsten struts with Bilsten sports shocks.
I considering Mueller's roller bearing upgrade for THE front.
Rear
Rear Bilstein Sports with adjustable spring perch and 175 lbs Eibach springs (per Jim Patrick's recommendations at Patrick Motorsports).
Rear Carerra Brakes
I am also considering Mueller's roller bearing upgrade for the rear.
Car will have the chassis stiffening kit welded in. Steel flares, and 9x16 Fuchs in the rear and 8x16 Fuchs up front.
Other possibilities
I may switch to the Boxster monoblocks all the way around.
Thanks,
Karl
Can you feel the love?
campbellcj
Apr 30 2003, 11:08 PM
There was a recent thread here about t-bar & coil spring rate equivalents.
The setup I'm about to try is 22mm t-bars, 22mm front Welt swaybar, 225lb rear coil-overs. I have a lot of room for adjustment on the swaybar and can easily swap the rear springs stiffer or softer for approx $100/pr so it shouldn't take long to get this dialed-in. I'll go to a Smart-Racing front bar before too long, probably when we pull the tank to do the cell and some replumbing.
I think 22's with 140's sounds out of kilter. Stock t-bars are a good match for 140 rears IMHO, as long as you have an adjustable front swaybar (19 or 22). My guess is you'd be better off with 180's or 200's.
Jim Patrick seems to favor soft rear springs. He suggested a 21/200 setup to me when I spoke with him last year. A lot of the other 914-6 guys seem to run 225-300 or more in the back.
tesserra
Apr 30 2003, 11:18 PM
Ed you are making me nervous. I am about to install the 320 brake system on all 4 corners. I have an adjustable (knob type) prop valve. It sounds like you installed the fronts and put some miles on them then installed the rears.? Do the rears need some time to "seat" before you start changing any more parts. Weight transfer, front to rear, should not make the car lock one side before the other. How about pad type, are they the same? I have had some funky braking when the wheel bearing were not tight. You should not need to change suspension parts to make your brakes balanced if they were balanced before. Have you figured out a park brake with the new 320i calipers?
Regards,
Tesserra
Brad Roberts
Apr 30 2003, 11:39 PM
I'm from the big bar softer spring school as of late. The large bar allows me to really fine tune the setup compared to changing springs in 25lb increments. Its much easier to adjust the bar than it is to change torsion bars and or rear springs. The large front bar also compensates for lack of torsion bars available for the car. The largest I can get in the control arm is a 26mm bar. Most places dont stock this.. so instead we go to coil-over... well... not everybody wants to go coil-over.. my thought: run a bigger front bar.
I have a car running around right now on the street with 21/27/200 and it ROCKS. 3.2 liter 9146 with Koni adjustables F+R. The car is very well balanced.
B
Evill Ed
May 1 2003, 06:17 AM
Thanks for all the quick replies.
The rubber brake lines are brand new factory ATE, I just put them on Saturday to replace my suspect SS lines. One SS line was staining blue,like the ATE brake fluid appeared to be wicking out of the SS cover from the inside line.
The locking fronts existed with the SS lines too, so the rubber lines are not the problem. All the steel lines are new, no kinks, blockages or damage. The master is new too.
The calipers appear to be perfect, pistons, seals and assembly.
The fronts pads have some milage on them, approximately 5k, the rear pads are brand new, and I'm sure that they are not bedded in yet. They seem to grab stronger and the pedal is less spongey as I put some miles on them. Maybe more miles will and full srface contact will make the rears grab quicker and harder.
I will check the struts themselves for wear or damage, although they only have 5k on them also. I will re-check all wheel bearings and components.
I'm not sure, but when I had full pressure from the prop valve last night and the rears were locking, I think that the right rear may have been locking a little early too. This seems like a right to left as well as front to rear problem.
If it is a balance issue, could this possibly be caused by me sitting on the left side, though I only weigh 180 lbs.
Like I said, the braking is strong and I can feel the effects of the prop valve at different pressure settings. The locking fronts at high speed hard braking is unsettling. When they lock, the front gets loose and you don't slow down.
Ed
Don Wohlfarth
May 1 2003, 06:52 AM
Ed, sounds like you have 5 series calipers on the front, 320 on the rear?
You want fronts to lock before rear, little easier to control car.
You may (?) have too much caliper on the front, but I'm not familar with BMW calipers. You may need larger front tires for more grip with this setup as you may be overpowering the tires ability to slow the car so it lock the wheel.
morgan
May 1 2003, 06:55 AM
This sounds like the same as my SCCA it racecar. I found that when I bleed the brakes , I have lock up at the right front too. after the brakes get hot a number of times, the brake peddle gets a little softer and I can brake much harder with out lockup. AS they said in harlly and the marborel man (SQueeze the trigger)
john rogers
May 1 2003, 07:45 AM
tesserra, I am using 320i calipers at all 4 corners and the front and rear lock just about the same time if I make it lock. Normally the braking is really even and smooth so don't worry about it as it is really worth the $$$ and time to convert. I use the 23mm m/c too so I don't have a lot of pedal travel. I am also using Goodyear slicks so I get LOTS of road traction with the tire. I also the small spot caliper that Wilwood sells as a parking brake, one for each side and I had to get custom cables as the stock ones were too short. I still leave the car in gear if I park it just to be safe. Ed, have you tried a residual valve in the rear lines? My brake system smoothed out some when I installed one for the rear brakes. Good luck.
kdfoust
May 1 2003, 07:47 AM
I dunno about the F vs R lock up issue.
I was experiencing right front lock up and pulling (it must be a coincidence) when I first bought my car. It was unsettling enough that I sent the car to a p-car mechanic that gave the brake system a clean bill of health (all stock). His determination was that the pads which were relatively new had not fully seated. I drove the car some more and found that the pull/lock up began to improve, but, was variable and appeared that it would never go away completely. The pads were Pagids - don't know the particular compound but very soft. I dumped them figuring that close to 1k miles to "bed" pads is totally unacceptable. Porterfield R4S pads went in all around. The car brakes straight as an arrow with no other changes to the brakes. YMMV.
Good luck,
Kevin
Evill Ed
May 1 2003, 07:57 AM
QUOTE(john rogers @ May 1 2003, 05:45 AM)
What is a residual valave? What does it do? I have a Titlton proprtioning valve at the rear just in front of the T fitting.
Ed
Evill Ed
May 1 2003, 08:01 AM
QUOTE(airsix @ Apr 30 2003, 08:01 PM)
-Ben
Ben, I set the stock d-jet dual canister dizzy to retard to 24 degrees BTDC at 8-psi boost. The inital winds up being 34-35 degrees BTDC @3500 rpm.
This works well for 8-psi w/out any intercooling on 93 octane.
Ed
john rogers
May 1 2003, 08:23 AM
Ed, a residual valve maintains a small amount of pressure in the brake system where it is installed which will keep the calipers pushed out slightly. Works well if you have a large mismatch in caliper piston size or a mismatched brake system. The pads don't actually drag anymore than normal so there is no problem with heat build up. Give Chuck at CNC Brakes in san Diego a call as he was the person who helped me out with brake questions (great guy). Good luck.
ChrisReale
May 1 2003, 09:54 AM
Kellezy,
Here is the thread about the trosion bars vs spring weight
http://www.914world.com/bbs2/index.php?act...&hl=torsion+bar
Brad Roberts
May 1 2003, 11:40 AM
Ed,
How much negative camber is in the right front ?? I run more on the right front than I do in the left front. My point: how much tire is on the ground with reguard to the right front ?
B
airsix
May 1 2003, 12:11 PM
Ed, thanks for the turbo info. Back to your brakes....
Not having any experience with the particular calipers you are using... Do they line up perfectly centered over the rotor? If they are off-center and you have worn pads one piston may be overextending and while not being out far enough to cause leakage, it could be getting jammed up. If exented enough the piston will wiggle in the bore. Under heavy braking it can 'cam forward' (go cock-eyed in it's bore) wedging the pad into the rotor.
Just more brainstorming.
-Ben M.
Jeroen
May 1 2003, 12:12 PM
I don't understand why you are concerned about locking the front wheels.
You don't wan't any locking of the rears (unless you like to view traffic behind you through your windshield)
The left/right pulling under braking is most likely a suspension problem.
Check the cornerbalance first, but unless it is off by a lot, that shouldn't be the problem.
Most likely it's the shocks...
cheers,
Jeroen
Evill Ed
May 1 2003, 01:29 PM
QUOTE(Jeroen @ May 1 2003, 10:12 AM)
cheers,
Jeroen
The problem with the locking fronts is when they lock. If I brake hard, like I do at the track, and the front(s) lock, I start to loose control of the front end and the car is not really slowing down anymore. I also wind up flat spotting my expensive street and track tires.
I may be desribing the problem wrong.
I know I want the fronts to be able to lock before the rears. I'm having trouble finding balance right now. Either I get too much or not enough rear braking. It seems to me that I should be able to slow down at a much more aggressive rate before the fronts lock.
I will check out the suspension components tonight. If I don't find any problems, i will put some more miles on the rears to be sure that the pads are fully bedded in.
Once I assure myself that the brakes are not the problem, I will realign the car and have it corner balanced. Does this seem like a reasonable approach?
I never checked the center line of the front calipers to the rotors, I bought the set up from Rich Johnson, and just assumed that all was right. But I will double check it tonight. Ben has a good point about the piston extending too far and rocking. Could be worn pads too. This problem only started last year, so something seems to have changed. Or maybe I just drive alot faster now ;^)
Ed
Evill Ed
May 1 2003, 01:53 PM
Duh!!!! I just remembered that before I stopped driving the 914 last fall, that the steering wheel was pulling hard to the right every time I slowed down. Sure seems like there may be an issue with the right front caliper or suspension huh? I'm gonna rip that bitch apart as soon as I get home tonight.
This is the problem with living on the East coast and not driving your 914 regularly, you forget shit. Maybe my highschool years are catching up to me.
Jeezzzzzzzzz
Ed
Evill Ed
May 1 2003, 08:09 PM
Okay, found the problem, fixed it, learned a few things.
The pads on the BMW calipers overhang the edge of the 911 rotors a bit. This caused a step at the edge of the pad that was rubbing on the outer edge of the rotor. The edge of the rotor was polished smooth. This was causing the lock up on the right wheel. The left side had the same ridge, but it was just starting to contact the edge of the rotor.
I took a grinder and cut down the ridge and put a slight bevel on it to prevent it happening again as quickly.
Now both front brakes lock evenly.
I have the proportioning valve set in position 6 out of 7. The braking is very strong and agressive. The fronts will lock first in an all out panic stop.
I need to double check the 320 calipers on the rear for pad overhang.
If anyone is using BMW calipers, be sure to check the pads often and correct any lips that form on the edges to prevent uneven braking.
Ed
