my car that is.
put the tank back in, jumped the fuel-pump and let the fuel circulate for 10 minutes and checked for leaks. hooked the battery back up, filled the fuse-panel with new fueses, made sure i had no short-circuits anywhere, hooked up the needed vacum lines and turned the key.
after sitting for over a year, the engine fired right up, idled fine and reved up ok. didn't have the muffler on, so it was a bit loud
no apparent leaks anywhere, now i have to change the oil and adjust the valves.
one step closer to have her back on the road!
