Harpo
Dec 31 2011, 05:28 AM
I have pulled my steering rack to install my new Turbo Tie rods. Is there anything else I should be doing to the rack? Can I add grease? If so where to add and what kind.
Thanks
SLITS
Dec 31 2011, 10:23 AM
Just make sure the boots are not torn ...... CLEAN light grease on the rack ends where they will slide into the housing. Debris can cut the seals and score the bushings inside the housing. I suppose you could pull the plate at the center of the assembly where the rack mates with the pinion and add some grease there too!. Articulate the rack while applying.
jmill
Dec 31 2011, 10:48 AM
There was a thread on this a few months ago. Do a search on it. My phone cant do the advanced search or I'd help you.
913B
Jan 14 2012, 12:27 AM
Search is not my friend. I rember the member avatar was datsun 510. Can some please send the link
