QUOTE(pilothyer @ Jan 3 2012, 11:51 PM)
Hello Clark.....There is one on Evil Bay right now for $25.00. The picture shown doesn't show clearly if the bellows are expanded but you should be able to contact the seller and ask....I have made several purchases from this seller before and was always happy with the item.........Also the one that works for the 914 but looks kinda funny has an inherent problem.....it defaults to the cold (closed) position..........Jerry
Crap the auction ended with zero bids. I had trouble finding it, cause he spelled Thermostat wrong. "thermostadt"? I contacted him tho. Thanks.
I was under the impression that the majority of the failures for this OE part (021 119 159A) is when the chemical leaks out and the unit expands, opening the flaps. I saw a Mexican type 1 spring version that someone said fails and closes the flaps.
