I am testing the waters to see if anyone is interested...So here it goes...
1976 2.0 (originally). The engine conversion is done (to a 3.0) All of the new parts used for the engine compartment were supplied by Richard Johnson (well known for quality parts and support) these parts include the firewall mounted engine mount, original oil tank, oil feed/drain lines, accelerator linkage...He also supplied the Big Red Brembo brake calipers on the fronts and backs, the 5 lug conversion, the back control arms were rebuilt with new bearings and re-enforcements (also done by Rich), the rear suspension has new Koni shocks and new coil-overs, the front suspension was rebuilt with new bearings and swapped with a 83' 911 SC (for the 5 lug capability)and includes the "hard" thick 911SC sway bar, the front shocks are also brand new Koni's, a Setrab oil cooler (from Patrick Motorsport) has been installed and tested, ALL of the rusted areas (almost none, was a California car to start) has been replaced/repaired with brand new steel from Automobile Atlanta, the interior has been completely replaced with new carpet and brand new fiberglass backed REAL leather (all from Appearance and Performance) the interior includes: new leather backpad new leather seats, new leather center appearance console (with leather gauge face, new leather console, new leather rollbars (front and rears top rear), armrest, new leather door panels, new leather armrests for the door panels and all of the new door hardware(window cranks, interior door pulls), The dash was replaced with the 5 gauge position Getty(911 style) dash,All of the gauges were rebuilt and tested by "Big Dog", the shifter has been replaced with a new JWest shifter and all of the bushings for the shifting linkage were replaced at the same time, the exterior door handles have also been replaced with newly chromed handles (AA again), ALL of the seals were replaced, All of the steel flares are on, the car is painted back to the original Silver, Newly chromed front and back bumpers (pre 75' bumpers( body holes drilled and ready)) with NEW rubber tops (VERY HARD TO GET)...I have both types of plastic chromed grills; the ones with and the ones with the fog light cutouts, new fiberglass front valance with production GT style oil cooler cutout, real 5 lug 7's and 8's Fuchs with new tires all the way around. The engine has been started and runs great. All that has to be done is to complete the wiring to the alternator and the engine compartment is DONE.
Other great things about his car:
New old stock seat belts (AA)
2 sets off new old stock Hella rear lens American and Euro
New front headlights
New torsion bars with associated hardware from Elephant Racing 22mm?..can't remember...
Aluminum center brace from 911 for front A-Arms
New ball joints
19mm brake master cylinder
all stainless steel brake lines with new soft lines to the calipers
Red painted fuel tank
New fuel pump
New "new style"-blade fuses- fuse box
New Solid engine and transmission mounts
Rebuilt Zenith carbs
NEW paint....Car was red when I got it...I went back to the L?? paint code (looks GREAT)
ENGMAN longitudinal reinforcements installed
New windshield with new seal
New seal on back window
New seals on the door windows and triangular windows
New vented rotors
New CVs and bolts
Essentially, everything that could be rebuilt or upgraded WAS...I made a point of using vendors/suppliers from 914 World and Automobile Atlanta
Special thanks to:
ENGMAN
George (AA)
Rich Johnson
Dr. Evil (for helping me get my transmission built in the waning hours of the clinic at AA...Thanks again George for holding the tools I lent during the clinic...
JWest
Elephant Racing
Patrick Motorsports
I'm sure I have forgotten a few others.....
Here is the HEART BREAKER...I have a job that puts me at home in Atlanta about 30 days every year and this car has been under a cover for 3 years; it has NEVER been out of the neighborhood...I am crying while I write this because I have been SOOOO wanting to drive this car, but, I can't "get in front of it" long enough to get it on the road.
As you might expect there is ALLOT of money wrapped up in this restoration/conversion (probably around 30+k)...Let me know what you think..
Did I mention I also have a newly rebuilt engine by Motor Meister. It was rebuilt and I paid the extra to have them start it up and run it to test. Its a 2.7 with all of the correct modifications (engine case studs, correct cams for the newly rebuilt Webers etc.....). Also a newly rebuilt transmission; this was rebuilt when Dr. Evil had his class in Atlanta; all the parts needed were replaced along with the seals of course....That is an extra REBUILT drive train as a spare for the car. These are both in addition to the the 3.0 engine and transmission in the car. Click to view attachmentClick to view attachment
