d7n7master
Aug 25 2004, 08:42 AM
This a.m. I noticed my volt meter was PEGGED. When I came to a stop, at an idle, it went down to about 14 volts. When I accelerated - it PEGGED again!!!
I thinkin' voltage regulator - YOU???
Thanks, Gary
ArtechnikA
Aug 25 2004, 08:46 AM
put a meter DIRECTLY on the battery posts and measure.
sounds like a bad VR to me but i have no confidence in the console meter...
don't run it long like that, too-high charging voltage will kill a battery in a hurry
Joe Bob
Aug 25 2004, 10:07 AM
Yep...those old VDOs are very trustworthy....
Aug 25 2004, 11:39 AM
QUOTE(ArtechnikA @ Aug 25 2004, 07:46 AM)
with both ...
don't trust the old gauge and don't run the car for much longer or it'll fry all sorts of things ...
Andy
SGB
Aug 25 2004, 12:21 PM
When mine did that, initially I replaced the VR, but that didn't do it. I had to replace the alternator. Really surprised me....
fiid
Aug 25 2004, 01:26 PM
Hijack....
DO more modern cars have the regulator built into the alternator? The subaru alternator seems to be piped (and I mean piped - 100amp fuse) directly to the battery!
Fiid.
ArtechnikA
Aug 25 2004, 01:41 PM
QUOTE(fiid @ Aug 25 2004, 11:26 AM)
911's since about 1978 or so.
'Murican iron for a long time...
KitCarlson
Aug 25 2004, 04:00 PM
The points in your mechanical voltage regulator are stuck. Very bad! Get a replacement solidstate regulator (I got mine at NAPA). Your regulation will be better and your battery will last longer. Your regulator is on the relay board in the engine compartment.
I know from experience with the same problem. I quick rap on the regulator broke the points loose and gave me the time to get the replacement.
Kit
d7n7master
Aug 26 2004, 09:51 AM
Done deal
Replaced the voltage regulator, alternator, belt, battery and ground cable.
All's well - Thanks, I'm happy that fixed it.
I had a car many years ago that fried the wiring harness when I shut off the engine. Damn vr stuck in the "closed" position. That was not a fun fix.
Gary
