The engine that came with my car was a late model 2.0. It fired up but made a racket. I shut it down right away. Turns out it was a stuck lifter. The lifter was toast and so was its corresponding cam lobe.
Next I bought a used short block with pistons. Same 914 engine code but the lifters look a little different, I do not believe they were Hydraulic. The cam in this block was good.
Now I have my parts back from the machine shop. Everything has been balanced and checked out and is ready to put back together. Like I said, the new to me cam is checked and good and the old push rods are all straight (the lifter was stuck in).
Question: I read that you want to match the lifters with their original cam and lobes. With that said should I use the replacement lifters that came with the "new" cam? If so, do the push rods need to be checked for compliance?
This is my first go at engine building and so far this is all that escapes me. (so far )
Thanks in advance.....
