Helping a buddy, who is helping his boss out via phone
Type1 in a Split window has a few issues.
In this pic, No current into battery when running. 12vdc at yellow/red terminal on top of alternator when running. Is there a external reg on these?
Issue 2 is 1amp draw coming from battery with key off and out of ignition, traced to 8ga wire going to Starter. Bus is air bagged and he has no lift or ramps at the moment, if starter solenoid is going bad will it start to draw juice on its own? I suspect he may find other things powered there, once he gets a look at the starter...
