QUOTE(Enhoover @ Jan 9 2012, 09:52 AM)
Hello Everyone.
I am new to this forum as I recently got my hands on a 73 914.. (originally a 2.0 car, but currently has a 1.7 in it which does not run) I fiugred since the 2.0 originality is gone.. i could do a v8 conversion. I was wondering how much power can the stock 5sp. side shift transmission hold up to. I read around the forum and the only thing i could find was that 1st gear burn outs is a nono... but nothing on how much power they could hold.....any knowledge would be greatly appreciated.
Hi Enhoover,
When I was starting my V8 conversion, I got a ride with a friend with a 300 HP Chevy smallblock and he romped through the gears with sloppy shifts with partial open throttle. In my mind, he was very abusive to the trans but it TOOK it. When I commented on the shifts, he just smiled and said "I have 2 other 901s under the house." His point that 901s are CHEAPER to replace than going to a BIG TRANS.
I've been following V8 conversions for some 10 years now and find a general consensus that 300 - 350 HP will allow the 901 to live. Of course the TRUE issue
is that torque that breaks trannies. An engineer bud advised me that the transitory SHOCK loads from sloppy shifts far exceed the load by simply applying engine torque when in a gear. So the bottom line is: run a "mild V8" and shift like a road racer, not a drag racer.
My car has a built 383 SBC and I knew that neither the 901 nor the 915 could take the torque. I HAD to cough the $$ for a 930 (4-spd). While it can take all the torque, the gear ratios SUCK: 1st- a bit low, 2nd- ok, 3rd-great shift from 2nd, 4th- is a very tall 5th with a .65 overdrive ratio. The box desperately needs 5 gears and Porsche corrected the issue with the G-50. 930s are scarce and run $2500 - $3500, G-50s run $3500 and up.
So there it is, now you get to make the choice. If a 300 HP Chevy works for you, I'd suggest staying with the 901. However, if you GOTTA' go big, you'll have to spend BIG...it's all about $$
Enjoy,
Terry
