Scott S
Jan 9 2012, 12:02 PM
Hi All -
I will be ordering a custom oil line for the discharge side of my -6 conversion, and just want to have my ducks in a row. Does anyone know the size of the discharge line fitting on the factory tank? is it a 26mm?
Thanks very much -
Scott S
Krieger
Jan 9 2012, 07:04 PM
You need to look at your tank to make sure. I had heard some of the tanks were different. My tank has two different sizes. 26mm (engine compartment access) connects to the long steel oil pipe that connects to the right(passenger) side of the engine case. 30mm (left rear fenderwell) connects to the aluminum pipe below the oil cooler.
