I'm close to having all the pieces pulled together to fix my front trunk. Something I've put off doing for over 20 years. The final piece I need is the left side piece outlined in red with the arrow.
The piece is the front left corner top plate that is welded to the trunk floor. The white outline below shows the area I'm working on.
The picture below is an OE right side piece. I need the left side.
Restoration Design will eventually add these pieces to their parts inventory but they are some time away from doing that. Automobile Atlanta did have the right side piece but does not have the left side.
I'd like an NOS piece or a section that is rust and damage free. If you have a donor piece and are willing to work with me, please give me a call or drop me a note.
In order to make a used piece work, it needs to be cut out so I can carefully remove it from the pieces it's welded to.
Thanks for the help!
Rich
214-478-9418
a914guy@aol.com
