The car: 75 2.0 d-jet injection.
the symptom:
car was running fine and has for the past 9 months since i put in new FI wiring harness and replaced the coil,wires,plugs,hotspark mod, temp.sensors , mps.
i have been driving it 4-5 days a week thru warm to cold weather and no problem,.
in fact before christmas it was 27 degrees and car started up and ran great, but at some point it would run fine, but if it sat for several days it runs very rough, like ist missing, misfiring or flooded out etc. so thinking it was flooding out due to leaking injectors, i check and tested those 2 were a little , cold start valve is fine.
-first i replaced the CHT , and put new FI points in and at first i thought that helped, it sure ran smooth for a few days - it was on the rich side and when i tested the CHT it was not at spec, i had one that was new and did, so i switched them out, -no problem seemed to improve , was not loading up like before,
in fact 2 weeks ago i even pulled the tank and put in new filters, checked for leaks etc just in case, all was fine. but it had been doing that if i drove it every day anyway- the problem seemed to be only if it sat for several days.
- moving forward, it continues so I order new Bosch injectors- i put those in last night, ran a little rough at first, seemed to clear out quick and ran it out for a half hour. ran great, good power etc. then parked the car and got up this morning go to start it and it barely starts!!!! like its missing or loaded up. - the only thing i can think of is the hotspark module is going? it does not seem to be fuel related- it thought it was -
timing , valves etc has all been set, checked. - after going thru all the FI and fuel i now think its electric, but that is all new within the past year!
I have verified all connections, all leads and wires. FI ground contacts were rechecked making sure of good contact etc.
suggestions ?
