Our friends at GPR make a front motor mount that is aluminum. Has anyone used them? Can I get some feed back on the PROS and CONS? One pro is that they cost about 1/2 as much as the OEM type rubber ones. Mid-Engine Mania sells them on the link below.
My only initial thought on the CONS would be the vibration transfer. Another PRO would be the nuts, they look to be the ny-lock type, that could be good. The OEM type have the square carriage bolt feature, can't tell if these do or not. I assume that keeps the OEM mounts from wearing from spinning?
My car is going to be a daily driver, no racing or AX, just some FUN.
http://www.mid-enginemania.com/products/91...nts-BY-GPR.html
Thanks in advance.
