Black914_4
Jan 11 2012, 05:16 PM
Hello all.
I have a 1974 2.0 914. I am only getting power to one bank of injectors. Only the drivers side are working. I switched injectors from side to side and the injectors are fine, although 2 are green and 2 are yellow. But all 4 work only when on the drivers side.
Does anyone have any suggestions as to were I should start looking for the problem? Only owned the car for a week and not realfamiliarr with these older cars but really excited about fixing this one up and driving her.
SLITS
Jan 11 2012, 05:29 PM
1.) Trigger points in distributor (requires dizzy removal)
2.) Wires from trigger points to injectors .. check continuity with VOM .. signal comes from ECU connector
3.) ECU harness grounds ...multi-tab attached to case bolt at flywheel end of case
Green injectors are correct for your engine ...
Yellow injectors are 1.7L and may cause those cylinders to run a tad lean.
Jan 11 2012, 05:39 PM
QUOTE(SLITS @ Jan 11 2012, 03:29 PM)
with all of the above ...
Black914_4
Jan 11 2012, 05:59 PM
#1 is good. Car had no spark when I bought it. Rebuilt/cleaned the distributor and got spark. I cleaned the trigger points and they worked good.
Fixing to go out and pull the ECU and check connections there.
I'll look for the ground wire while I'm out there.
Kinda seems funny to me that only one side works.
Jan 11 2012, 06:14 PM
QUOTE(2xs performance @ Jan 11 2012, 03:59 PM)
Not really, that's how the FI trigger points usually fail ...
underthetire
Jan 11 2012, 06:16 PM
Wrong trigger points i'm afraid. These are at the bottom of the distributor.
Black914_4
Jan 11 2012, 06:20 PM
Item #3 wins! lol
It was a wire on the ground that had came off.
Thank you very much.
Black914_4
Jan 11 2012, 06:24 PM
QUOTE(underthetire @ Jan 11 2012, 09:16 PM)
Those were the ones I was talking about. They slide out of the side and has 2 triggers for the injectors.
It's been converted to electronic so there are no points.
Cap'n Krusty
Jan 11 2012, 06:27 PM
QUOTE(SirAndy @ Jan 11 2012, 04:14 PM)
Not true, Andy. Gotcha! They fire 1/3, 2/4.
The Cap'n
Jan 11 2012, 06:44 PM
QUOTE(Cap'n Krusty @ Jan 11 2012, 04:27 PM)
The Cap'n
Dang! And here i thought they fired per bank of cylinders.
I stand corrected ...
Cap'n Krusty
Jan 11 2012, 07:39 PM
It's OK, Andy. You can sit down. Then you can send us some fuzzy pictures .....................
The Cap'n
