For those bored few who are following this saga, you may remember that I had to pull the transmission to see why the clutch wasn't working. The clutch fork just flopped from front to back with no resistance. Thoughts ranged from broken fork, bad release bearing, etc.
Well, I got it pulled tonight and here are the pics. I have not pulled off the pressuere plate. So, based on what you see what is the verdict? See anything obvious? Would a clutch stuck to the flywheel cause this symptom?
