914Gelb
Jan 13 2012, 02:58 AM
Hello 914 friends,
please tell me your experience, work methods and used tools to remove old paint.
I've heard a lot of different ways for examlple MPX, sand blasting, and so on but what is efficient and sparing to the sheet metal.
d914
Jan 13 2012, 08:27 AM
Soda blasting works well for removing paint and doing little damage else wise.. It does NOT remove rust. It does need to be washed off with a mild acid wash, vinegar solution or such, it doesnt harm glass trim or wiring...
Not the cheapest.
Do it yourself.. aircraft stripper ,plastic and patience.
You have a compressor,,, DA???
Jan 13 2012, 08:30 AM
There are tons of threads on this site, pelican and probably many other auto sites. It's worth doing a search to get all the + & - for each method.
pete
Jan 13 2012, 08:41 AM
I'm working on my engine compartment stripping the original paint. I found that Aircraft Stripper works the best if you don't want to splurge for professional soda blasting. Oh, I tried soda blasting myself with a 50 pound HF soda blaster and I can't even tell you what a mess it makes and VERY slow progress. I also tried using 2-3 other strippers such as POR Strip (useless) and a few sold at Sears (useless as well) Aircraft Stripper is the best and twisted wire wheels. Oh and this thing:
http://www.harborfreight.com/6-piece-pneum...-kit-95826.html works great at removing most of the seam sealer and then Aircraft Stripper to remove the rest.
Krank
Jan 13 2012, 07:11 PM
If you intend on using stripper, try furniture grade varnish remover. Basically works the same as industrial paint stripper but about 2/3 the cost.
Type 47
Jan 13 2012, 10:49 PM
soda blast...but it doesn't remove rust. do you really want the rust? Do you want to go back and redo something you short cut b/c at the time it seemed cost effective.
saigon71
Jan 14 2012, 08:01 AM
I have a collection of wire brush attachments for the drill and Dremmel tool that I use. I buy the dremmel attachments in bulk from ebay. It was my best solution considering my space constraints. When you are done for the day, you just sweep up.
