96740
Jan 13 2012, 07:11 PM
I ran across this picture on Automobile Atlanta's Facebook page. Funny it's same color as mine. I LOVE HOW LOW THIS CAR IS! How do you get it this low? What set up is this?
Andyrew
Jan 13 2012, 07:21 PM
Adjustable rear coils and adjusting front T bars.
Pretty easy..
messix
Jan 13 2012, 07:24 PM
and then you have no more up travel in the suspension.
nice rough ride!
96740
Jan 13 2012, 07:25 PM
Adjustable rear coils? Like the PSS9 coil overs?
I can see the TB working, crank them down and then get the car aligned I assume. Will the car be able to be aligned with the TB turned down so far?
96740
Jan 13 2012, 07:27 PM
QUOTE(messix @ Jan 13 2012, 05:24 PM)
nice rough ride!
That too.
dadaDaveed
Jan 13 2012, 07:55 PM
Or raise the spindles on the front struts to keep the front suspension geometry correct, right?
ottox914
Jan 13 2012, 08:26 PM
QUOTE(dadaDaveed @ Jan 13 2012, 07:55 PM)
Yup, but with factory 15" rims there is only so far you can go. Now if you wanted to run some 20's under GT flairs...
jmargush
Jan 13 2012, 08:58 PM
with stock wheels you can raise the spindles about .75" then adj the torsion bars just a little so you don't mess up the geometry
toolguy
Jan 13 2012, 09:21 PM
My rule of thumb for a safe alignment. . set the rear height so the axles shafts are just a tad of downward angle, meaning about 1/4 inch higher at the trans. slopping down to the wheels but you need stiff springs also. . then set the front at 1/4 inch to 1/2 incl lower than the back with a 1/2 inch steering rack spacer which should give the tie rods about the same slope as the rear axle shaft. .
bandjoey
Jan 13 2012, 11:29 PM
Can't believe no one has told him the truth yet.
Lower the lift to the floor!
bulitt
Jan 14 2012, 02:49 AM
Bought this car in October, must have the same drop, and it rides rough. The front adjusters are wound all the way down. Going back up slightly when 5 lugs and flares finished. Not as low as your pic.
