So I was looking at simple ways of improving the braking system on my car and read the PP article on the 320i front caliper upgrade. Then I search the forum and found many threads on the subject. I also really appreciated Eric Shea's comments on the bias and the proportionning valve (or anti-lockup valve).
Let me describe my setup: stock 2.0, Fuchs, sway bars, 100lbs rears, 195/65. Spirited daily driven.
In vue of my reading I have 3 topics/questions on this:
1- Isn't there a rear caliper available that could be used in the back that would be proportional to the front 320i yet keeping the hand brake?
2- Why would someone want to switch to 19mm MC in the stock setup? Yes you will get a quicker response but you will also need to press even harder on the pedal.
I can understand it if you replace the calipers to larger chamber volume.
3- Per Eric's suggestions, I could simply make sure that all my calipers work properly, adjust the gap on the rears, and invest in good pads. But then which of the suggested ones more specifically:
Porterfields R4-S: AP30 or AP31?
Hawk: HB172F or RHB172F?
KFP Magnum: KFP-30 or KFP-31?
Thank you,
