QUOTE(Cap'n Krusty @ Jan 16 2012, 07:29 AM)
That relay in the turn signal flasher relay p[osition sure doesn't look like the correct part ..................
The Cap'n
Thats because it is not the right part. That was my screw up initially. Put the original flasher relay and I got everythig back.
My new delima is this. I was sent a 40a relay for the new headlighs from PP. Tried to install that new relay and I cant get the lights to work. I figured out the following (at least I think I did) for the wires leading up to the relay.
Red wire, power
White wire, high beams
Yellow wire, low beams
Yellow/Red wire, high/low switch
Ok, so I wired the new 40a relay as follows,
Red into the 30
Yellow/Red in the 87
Yellow in the 85
White in the 86
Looking at the pic, does this look like the right way?
Click to view attachmentNothing is working. I put on the old relay and everything works again as normal. My concern is that the new lights are too much for the old relay and it will eventually fail.
Any ideas?
