I need to remove the tension for my Weltmeister rear sway Bar. My questions are:
1.)Should I remove the bolt that goes through the drop link or loosen the clamp that slides along the bar?
2.) Does the bolt that goes through the drop link hold the shock to the trailing arm?Can I disconnect one without the other?
It seems removing the bolt that goes throught the drop link is easier, but I don't want to disconnect the shock.
