Joe Bob
May 1 2003, 06:24 PM
How many?
Bleyseng
May 1 2003, 08:31 PM
50 or 55 amps Mike, if you want more install a bus 75 amp one.
Geoff
Rog914
May 1 2003, 08:33 PM
I think it's 50 amps
Ralph
74 2.0
Joe Bob
May 1 2003, 08:40 PM
Thanks....I was remembering 65. I just ordered an 80 amper for the Type IV.....needed some more omph for the electric fans.
john rogers
May 1 2003, 09:05 PM
Mike, check to be sure but I think two of the connectots at the alt or the relay board are swapped.and if you use the same wire harness you'll cook the batt very quickly!!!???
Brad Roberts
May 1 2003, 11:19 PM
Mike..
make sure you get a ONE wire GM alternator. Very easy to run the chargeback wire to the starter.
I use a GM late model truck alternator for tow package (110amp) The late V8 caddies also ran this setup.
B
