Full Version: like, where do you use locktite man
machina
seriously,
I had to dissassemble the blower housing, impeller, motor mts to tighten oil line.
It looks like jake used locktite on the housing retainer bolts but the impeller bolts looked pretty dry when I removed them.
So when I re-assmble, should I just locktite everything to be safe? I'm using the red 721 I think.
dr
TimT
use blue , the red usually requires heat and/or serious impacts to remove
oh btw on motor mounts and stuff like that Ive never used locktite
