QUOTE(mrholland2 @ Jan 23 2012, 07:49 AM)
The people of the "smoggy" states should advocate for autos over 30 years of age being exempt. That was the original intention of the law in some states, but it was changed. Since it is likely that cars over 30 years will have been substantially rebuilt, the smog requirement is pretty stupid (and I"m a big believer in reducing emissions)
FYI - that was where CA started - with a rolling 30 year old vehicle exemption, which was changed in 05 to stop at 75 MY cars, thanx to the overzealous types who want to see ALL old cars junked!
Michael - you asked about other smog states, so FYI to the south of you in CA - technically the 75 & older (and prior rolling 30 year) exemptions only apply if you have the original engine & all smog equipment intact, although currently they don't have the personnel, specs, time nor funds to do so - but that will change once they "discover" it as a "revenue enhancement" (aka fines & fees for budget balancing)!
Also, in CA the seller is responsible to smog check the cat being sold if not done in the prior 6 months for registration, and anyone bringing a car into CA must show that it still has it's state of original sale when new smog controls still intact.
Also in CA if you modify a car, you can do a same year or newer set-up - and it must include all of that year's smog equipment - but if newer, then they consider you under the newer MY's smog requirements, which may eliminate your bi-annual smog check exemption (e.g.: for those doing say an 80's H-6 conversion from a 911). Do folks get away without this - yes, but they'll get snagged eventually I suspect if caught at the seller smog check point later on.
Hope this helps for one state anyway!
Cheers!
Tom
