elwood-914
Aug 27 2004, 09:13 PM
Help! The generator light came on. Everytime I activate the turn signal or brake or put on the em brake the radio stops and the tac jumps and I have no brake lights. I have replaced the voltage regulator and no change and the voltage at the battery seems just fine. Tonight I have no tac and no brakes or turn sygnals. Bad ground?? The car starts up fine and other than the problems described
the car runs fine. Bad grounds
GaroldShaffer
Aug 27 2004, 09:28 PM
BTDT, Bad grounds. Check the tranny ground strap. 1st make sure there is one and disconnect it and clean clean clean the connection points.
Cap'n Krusty
Aug 28 2004, 10:29 AM
Check the fuses. Most common cause of the problem. The Cap'n
Brad Roberts
Aug 28 2004, 05:19 PM
Yep. You probably knocked out a fuse on the fuse panel with your feet (if you have no cover)... I *think* it is no. 7 that causes this.
B
