I am going to a rear coilover setup on my 73-2.0L. I have acquired the following components:
1) Koni Sport (yellow) adjustable shocks with 3 slots for spring perch cir-clip.
2) Ground Control coilover adjusters
3) 150lb Eibach springs, 2.5"ID, 10.25" free length
My question is: for close to stock ride height, will I need zero-rate helper springs to avoid unseating the main springs when the suspension is fully extended?
When I assemble all the parts, I can raise the spring perch high enough to put the spring in slight compression. But that may result in a ride height that would be way too high.
Any and all input would be greatly appreciated.
TIA
