QUOTE(brp986s @ Jan 26 2012, 02:26 PM)
... The advertised CR is 9.8, so that was good enough for me.
... Then measured the head/piston clearance with putty.
I know these are the 9.8:1 spec pistons but still need to measure absolutely everything fro myself. Putty is my friend and is definitely gonna happen with the buildup, but that's after the cams and springs are specified and installed. The motor came to me with 3L heads... not the early ones with big ports. I'm using 3.2L heads now and might, although these pistons aren't supposed to need it, relieve the heads a bit around the inside circumference of the dome. The 3L heads were. Both 3 and 3.2 heads are 90cc give or take what one does with the valve seating and piston relief.
The cam and proper springs are the outcome of this and I'm with you, gotta measure it all to get the base shims just right. It's funny how very little change in deck height will move the cr up and down.
Thanks for the info gents, including the bump JT!
