the PO bought the car in KS and shipped it here and is a mechanic in LI who collects old cars. He then lost his storage garage space and had to sell 2 cars, he hadn't even registered it yet. That's how I found it. He did put a larger master cylinder on it, 1 new injector, monza exhaust, and changed some seals. I have gathered parts to do a Suby build but feel a little bad cutting this car up...not so bad that I won't...but bad enough to give her a chance.
I've noticed a couple of drops of oil where I park it and since march I've added 1/4 quart, but doesn't smoke or appear to be burning it.
Paint is original color and has had a re-spray, about an 8 out of 10. The car is not concourse, but is very clean.
A rock hit the front windshield when I was driving to PA so there is a chip, hasn't spread yet.
I have logged every mile and day I have driven since I've owned it and love driving it. I've put maybe 2k miles on it and it has less than 80k original (odometer works!)
Never been wrecked, at least not that I can tell; everything is straight and no dimples in crumple zones.
Interior is fine. No cracks in dash. All gauges and electronics work, but the wipers have to be fiddled with and the radio is not original and is junk. A past owner put speakers in the door which are also junk, he also put in an electric rear trunk pop. The seats have some small cracks but all things considered are in good shape.
On the grill the "S" is gold while all the other letters are silver
I know from peeking through the jack hole in the rockers, that the jack points are bad and will need some work, but I haven't taken the rockers off yet. When I was looking at it to buy I took the top off, rolled the windows down, held my thumb over the door gap and put all my weight on the door & felt no flex or movement in the gap. The doors opened and shut with no issues. I felt around under the battery and where that shelf meets the fire wall and couldn't feel any rust. He put it on the lift for me and the floor pans were solid, as were the mounts for the A-arms and as near as I could tell the rear inner console where the trailing arms connect.
The drain hole under the battery was clean. but I did a hole about the circumference of a pencil tucked away; i pushed around it and felt no flaking but can't get a clear view with engine still in.
Rear window rubber on the bottom is bad. Front blinkers are weathered.
It developed a fuel leak up front, I think from it sitting with e85 for a couple of months, and I bought replacement hoses and clamps from Chris at tangerine and plan on fixing it around the 16th of this month at which point it could be driven away.
Trans is side shift and seems to up shift and down shift well through gears with one nuance; from rev to 1st easy. 1st to second easy, but finding first after a complete stop after 2 mins of driving can be tricky, I generally down shift to 1st before stopping and hold the clutch in. Only 914 I've driven so I don't know if that is normal after hear the term S.L.A.P.
That's everything I know about it.
A gentle man from NJ is interested in buying the eng w/fi ,trans and headers if I decide to use it as a conversion car. But he knows I'm on the fence about using this one as a base. He's driving to PA the 16th to hear the eng run and drive around the block before it gets pulled it. After that there is no turning back
I think I can strip out what I don't need and get around 2500 - 3k from those parts and have a good base to work from, but am waffling since its low mile and mostly original.
I need
peace,
Chuck
councilc (at) gmail
Click to view attachment Click to view attachment
