Another option was the factory option to paint in the body color (Fuchs & Mahle 4-lugs 74 on), and the Japan version of the LE Cremescicle used Phoenix Red Fuchs 2L wheels instead of the USA LE's Mahles in that color.
I ended up buying a set of 5 of the Phx. Red Fuchs from a member here to restore to the original polished/satin finish, but then got SoCalAndy's already restored set. 914sixer was going to use them on his Cremescicle resto, before he decided to get out of 914s. So I guess I'll eventually sell them to someone else who wants to do that LE/optional wheel look 914, or else I'll do a self-restore to polished & use them for DD/AX tires on mine after the resto.
Here is a pic of them FYI, and they had been oversprayed silver by a prior owner, then the seller used acetone to remove the silver & in spots of the Phx. Red removed to the greenish chromate primer underneath, as used on aluminum aircraft skiins/parts aluminum alloy wheels, since these are a quality job done by Fuchs for the factory.
Hopefully it at least gives you an idea of yet another 4th option which would match the body color on yours!
... but I don't know if you can add to your poll at this point, maybe one of the admins can help you if you wanted to consider this look too?
Click to view attachment Click to view attachment Click to view attachmentI suppose you could also have another alternative with the windmill petals & rims polished & only the background Phx. Red....
Cheers!
Tom
