QUOTE(Jeroen @ Sep 3 2004, 03:50 AM)
QUOTE(airsix @ Sep 3 2004, 08:20 AM)
I think this is a great idea because I'm of the opinion that the rear suspension is the real weak-point of the 914 once you've caged it and taken the rubber out of the front suspension
Why would you think that?
Weak, as in not strong enough or weak because of the trailing arm design
Sorry Jeroen,
My comment was poorly worded. When I said "weak point" I meant to say the rear suspension is performance-limiting, not structurally weak. It's heavy, not the best geometry, and it twists and bends a lot under load. Porsche's more modern multi-link designs can control the tire much more effectively (less unwanted toe & camber change)
-Ben M.
